Old 05-28-2009, 11:12 AM
oldskimmer is on a distinguished road
Unhappy Help with Mach3, Vectric
Need help running mach3 & vectric 3d for great art. The problem is 2 fold. The mach3 drops out occasionally at random. Question is how to restart after resetting and continue on cut program without miscuts, and why did it drop out inthe first place? Any possible help would be appreciated.
Old 05-28-2009, 11:14 AM
ger21's Avatar
Can you explain what "drops out" is? A little more detailed info?
Old 05-28-2009, 11:19 AM
Sorry, Mach 3 drops out, stops, requires reset then start as if emergency stop had been pushed.
Old 05-28-2009, 12:41 PM
ger21's Avatar
Is there an error message on the screen?
Old 05-28-2009, 04:16 PM
No, no messages. Just stops!
Old 05-28-2009, 04:42 PM
ger21's Avatar
Do you have a licensed version of Mach3? Without the license, it'll stop at 500 lines of code.
Old 05-31-2009, 04:05 PM
Yes Jerry it is licensed, but you bring up a good point to check what I'm using.
Old 05-31-2009, 04:11 PM
One other "dumb question", when mach3 stops from emergency button or whatever, what is the proper way to restart to continue the code without scrapping the workpiece?
Bob
Old 05-31-2009, 04:33 PM
ger21's Avatar
If you know where it stopped, you can scroll down to that line and use run from here. If you know the line #, you can also enter it and use "Set next line" and then Cycle Start.
Is the other problem fixed?
Old 06-01-2009, 07:17 PM
No, problem still there. If I learn to restart properly, at least I won't scrap the workpiece while looking for solutions. Thanks, I'll try it next time.
Bob
  #11   Ban this user!
Old 06-30-2009, 03:53 PM
My solution to the problem was to add 4 reed switches, wired normally closed to mach3. Each is operated by normally open limit switches. Works perfect, never has a false stop, never affected by stay interferences, does not require shielded switch wiring.
Newbie- Which Vectric Products do I need? ntww Vectric 8 06-25-2011 05:25 PM
Vectric-PPs for USBCNC elses Post Processors 1 11-04-2009 04:24 PM
WTB Vectric tdnp Vectric 1 03-22-2009 10:43 AM
Vectric College Course SPEEDRE Vectric 5 06-24-2008 09:42 AM
Vectric - Plasma CNC Switcher Vectric 3 05-27-2008 10:37 AM
