Old 05-27-2009, 10:46 PM
oldhack is on a distinguished road
What me worry build
I purchased joes new 4x4 plans and started building with a few tweaks of my own. I thought maybe everybody here might learn from my mistakes and get a chuckle or two out this build. I liked Joe's easy to understand plans but decided to mod a little. I went 4x8 instead. here are some pics of my build as I stumble through.
Started with 2x2 1/8 wall tubing, then 2x4 14 gauge tubing on sides.
It echoed a lot in the garage with my mockup rollers, so i filled the 2x4 tube with foam to quiet it. Last Pics is the rail system i used. its 1x1 hot rolled cheap angle iron and i welded 1/4 x 2 inch cold rolled flat stock for the rail.
Im using Ahrens skate rollers. Ill show them in future pics. I have 4 inch wheels and 1-inch rod for levelers.
So far so good. Im a large 32nd off from one side to the other but i dont think thats gonna make a difference. Ill try to keep this post current as i work on things. Im trying to make my gear reduction box for the rack and pinion. Rack will go in the center of the 2x4. All I can do is mess it up.
Name:	cnc machine build 004.jpg‎
ID:	82040   Click image for larger version
ID:	82041   Click image for larger version
Name:	color foam.JPG‎
ID:	82042   Click image for larger version
Name:	foam closeup.JPG‎
Old 05-27-2009, 11:19 PM
FandZ's Avatar
FandZ is on a distinguished road
Man the machine looks bigger than your tracker. What you plan on making? Also does the foam quite it down a lot? When you tap on the side is it just a dull thud?
Old 05-28-2009, 10:18 PM
5x10base
Its not that much bigger than a sheet of plywood.I will be able to do over sized 4x8 sheet goods. (49x97 etc) Im not sure what ill do with it. Maybe rubber stamps/foam/signage/trophies/cabinets/musical instruments/toys etc. who knows, but it will be a destination to look forward to.
Yes its a dull thud instead of a pipe ringing echo.
Old 05-28-2009, 10:53 PM
FandZ's Avatar
I look forward to your progress. I'm designing my next cnc and I may just have to use your foam technique on it
Old 05-28-2009, 11:47 PM
foam
very cheap insulating foam (3 us dollars) for filling cracks. It took 2 cans per 10ft .
Old 05-31-2009, 11:46 AM
My rack in place
Heres a pic of my rack in place. . It a 1/2/ inch away from the frame. Anybody do it this way before? I couldnt find anything when searching. Will it twist without support behind it or should I fix it?
ID:	82233   Click image for larger version
Old 07-14-2009, 12:10 AM
ahren's Avatar
ahren is on a distinguished road
That's quite a beast of a machine! Very clever with the foam. I definitely should have done something like that for my initial test videos of my new R&P setup (or at least covered the mic It also looks like you have a good span on the rollers -- should be a really stout machine.
I'd love to see some pictures of your gear reduction. What motors are you planning on using?
Ahren
www.cncrouterparts.com
Old 08-05-2009, 08:54 PM
long time coming
Ahren
Well im back
here are some pics of my progress. Ahren, im using your rollers and their rolling fine they are 10 inches apart. keling 640oz 4 wire 4amp with a 3:1 gear reduction.heres the pieces of the gear box. and you know those bearing blocks are not all square! so I had to shim some of them to make them work. Im using xl gears 20 /60 tooth gears/20tooth pinion and 80 tooth xl belt from belt palace .
ID:	85780   Click image for larger version
ID:	85781   Click image for larger version
ID:	85782   Click image for larger version
Old 08-05-2009, 09:10 PM
more pics and gantry
so heres the gantry side. You can see what I started with and what I ended up with. We have lots of alum scrap, so that saves me a bunch of money. And to think I started with Joes 4X4 plan and this is what it looks like now. If it wasnt for Joes plans, I never would have attempted this. His plans are so simple to understand, that even a dummy like me figured it out.(grin)
The top bridge is 10inches wide and on top of that will be a 4x6 aluminum tube which ill arrange all the z-slide stuff. If I dont screw it up. Im making this up as I go and so far nothing has fallen off!!!(grin) Next msg is about the z slide and some parts I found.
ID:	85785   Click image for larger version
ID:	85786   Click image for larger version
Old 08-05-2009, 09:16 PM
z slide parts
Here is where I really dont understand the concept of a backlash nut. I found these parts at work. Its a 10 per inch screw with a backlash nut i think. I just dont know how Im going to use them and what parts i need to make them work. Ive seen a few pics of z slides using this springy type nut but nothing definite or clear enough for these ole' eyes to discern. Anybody know which side is up or a way i can use these? I assume the nut has to be screwed to something. If you have a pic, id like to see it.
ID:	85788   Click image for larger version
  #11   Ban this user!
Old 08-05-2009, 09:53 PM
FandZ's Avatar
Glad to see you making progress on your best.
I haven't seen one of those anti-backlash nuts before, but that doesn't mean much coming from me. I would think the threaded side would be the bottom on a Z axes. Run it through a bearing block on the bottom and use a nut to hold it on tight. You could then use the top non threaded side with a another bearing block and a coupler to connect it to your stepper. Best I can come up with on the spot. Hopefully someone else can give you some better ideas.
Old 08-05-2009, 10:00 PM
ger21's Avatar
The nut's usually screw into a flange that can be bolted in place.
http://cgi.ebay.com/15-16-16-RH-Flan...d=p3286.c0.m14
http://www.roton.com/Flange.aspx?line=Recirculating
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
New Large Table Build in Houston, TX (Build Log) anitel Plasma, EDM and other similar machine Project Log 12 12-30-2008 02:45 AM
Problem- Something that I worry about JROM General Metalwork Discussion 9 05-22-2008 07:26 AM
driver short worry -- Kl-8078 endgrainguy General Electronics Discussion 0 04-29-2008 01:40 PM
