I'm just finishing my cheapskate's CNC build....the last thing I need to kludge is a Dremel tool mount for the Z plane. I intend designing my own Dremel mount (unless someone has already done this & can supply the G-Code - It's a Dremel 300!). Today, I had my first trial run with a 1/8" endmill in my Dremel, which I'd clamped to the Z plane. Truthfully, it was all information overload, but I was almost cowering in the corner thinkng that the endmill was going to snap leaving me with it embedded in my cheek! So this got me pondering.... So as not to end up with a shiny 1/8" endmill embedded in my cheek, to cut 1/2" MDF with a 1/8" endmill on a Dremel 300, what... Speed should I set my Dremel What should I set the feed rate What's the maximum depth I should I go for with each pass. After I've made this toolholder, for the foreseeable future, my CNC machine is only going to be cutting 1/8" plastic, so I don't need to think about upgrading the Dremel just yet. |
| This may give you an idea, it is from Onsruds website and really is designed for thier cutters. I have yet to use any of them as I am still building my machine but alot of people like Onsrud cutters. https://www.onsrud.com/xdoc/FeedSpeeds that may help you pick a good feed/speed setup for your cutter in your machine. |
| Buy a piece of lexan. Mount it between you and your machine. No more fear of cutters embedded in you. Make sure it's lexan and not something else. I have one that's easily removable. Keeps the metal chips on the machine instead of all over me which is the real reason I set it up. |
| modifying Carbide endmill shanks"cutting them shorter" | kojack | Metal Working Tooling | 6 | 05-26-2009 11:08 AM |
| Newbie- "Acrylic" Carbide Endmill ? | yngndrw | General Metalwork Discussion | 11 | 03-12-2009 07:43 PM |
| Need Help!- Advice for cutting .002" shim stock w/ endmill | stipierreinc | General Metal Working Machines | 9 | 01-29-2009 09:19 AM |
| Need A Quote- Wire for foam Cutting "EdgeSweets" machine | singerdon49 | Employment Opportunity | 0 | 12-29-2008 08:12 AM |
| Using Dremel 3/16" Bits In My MaxNC | roys29 | Benchtop Machines | 0 | 12-12-2005 08:59 AM |
