Hi gang. I'm a long-time lurker, who has finished designing and accumulating about 75% of my cnc parts, but am at a loss on dust collection. I have done an extensive search here, but without direct experience on how much dust is generated, I am even more confused than I was before ... The problem is that I am going to be operating in my father's garage, so cleanliness is paramount. My Dad notices even fine dust on anything (think O.C.D ), so a GREAT dust collection system will have to be designed into the unit from the get-go. The cnc footprint is 52" x 36" and it will be used to cut mainly wood, plastic, and some aluminum. I am thinking of using a large shop-vac that I own and venting the collection exhaust out of the garage so fine particles are not distributed indoors.My questions are: 1) Will a shop-vac suffice for this or will a "cyclone" type collector be necessary. Space is also a consideration. 2) How effective are the router attached "dust hoods" I see everyone using? Will they substantially trap all airborne particles? 3) I am considering completely boxing in the CNC with a dust hood/box unit to entrap dust. This would be the least preferable method, but brute-force will be necessary if option #2 is not effective. Has anyone done this with their cnc?? Thanks for any clarification you can provide. |
| The problem with using shopvacs is not the exauhsted dust but the lack of dust pick up. With a brand new filter and a nicely design system it will just be a short matter of time before you loose the suction to dust. Even with most over the counter dust collectors you will have dust getting through the bags. Your best bet is a cyclone, but takes up mores space requires more power than a shopvac and usually are not portable so if your dad wants to park the car in the garage it might not work for you. You should google Bill Pentz. His website is filled with great information on dust collection. I short/cheap alternative is to get a cyclone for your shopvac. I dont want to say this is the best thing in the world because I recieved mine in the mail right before my trip and I will not be able to run it for another week or two. http://store.oneida-air.com/dust-deputy-diy.aspx |
| found one on the cnczone so i made it and works great cutting mdf, no dust outside the machine as long as the boot stays over the job its perfect for my garage. Here's the link for the one i made. http://www.cnczone.com/forums/showthread.php?t=67663 |
| I have used a shop vac to clean up loose dust and they quit working very fast if you do not keep the filter cleaned (note...all the time). I bought a dust collector from Harbor Freight and it works so far. I know it doesn't move the rated amount of air, but it works much better than a shop vac. I got my dust collector for $157 including tax. Getting every drop of dust is almost impossible. Venting outside may be frowned upon by close neighbors and the dust can still gather where it exits. I am going to use Bill Pentz's cyclone plan for my machine when I can afford it. Check out Clear Vue Cyclones cyclones. Sean
__________________ www.FreeCNCPlans.com Last edited by freecncplans; 05-27-2009 at 07:20 PM. Reason: Error in URL |
| Hi Sean, you might want to check your URL - it links to discovery education store ![]() try www.clearvuecyclones.com instead Dave
That said, if you can vent outside you are 3/4 of the way there. A delta dust collector will do pretty well with a 4" tube if you use a floating brush setup to trap the fine dust. If you must vent indoors, Bill Pentz's system is probably the best. Regards, Nate www.finelineautomation.com |
| I have a neighbor that vents his dust collector through the wall of the garage to the outside but has the bag filters outside, so it basically gets most of the dust out of the shop but also keeps most of it from the outside air. Alan
__________________ http://www.alansmachineworks.com |
#10
| Oops, sorry bout the incorrect URL. I guess that happens when I stay up too late. ![]() As far as blowing the dust outside, we are in the country on several acres and my father-in-law owns the land next to my shop. He doesn't even live here anymore and we pretty much do what we want with it. I would blow all the dust out, but I need to collect some of it so I can dispose of it in the dry state. Sean
__________________ www.FreeCNCPlans.com |
#11
| There are some good dust hood designs scattered around the CNCzone. For a few years, I used some clear plastic as a skirt with a 2.5" dust hose connected to my Oneida cyclone. This was ok, but the plastic occasionally got caught by a bit, or got pulled up towards the air intake causing it to loose suction. For me, this has been a much better design. I can use very small cutters, all the way up to 1.5" diameter. The brush (door seal brush) creates a good seal, focuses the air around the cutter, and remains very flexible for 3d cuts. I can still see what is happening around the cutter. You can design for different height brushes if you anticipate a wide range of Z movements or very long cutters. Steve |
| Dust Collection and Brushes | Gibbon | DIY-CNC Router Table Machines | 11 | 01-14-2012 12:31 PM |
| dust collection | cabnet636 | Camaster | 9 | 02-08-2009 05:48 PM |
| DUST COLLECTION | KustomKoncepts | Commercial CNC Wood Routers | 19 | 03-15-2008 09:54 AM |
| gorilla cnc dust collection | woodman08 | Gorilla CNC Machines | 5 | 01-10-2008 06:28 PM |
| dust collection for graphite? | tmt_92021 | Moldmaking | 4 | 03-21-2007 11:40 PM |
