Old 05-17-2009, 03:00 PM
pavlo is on a distinguished road
Proposed router design. comments please
Hi I have wanted to build a router table for quite a while now and thanks to this forum I think I have a good chance of doing it.
I recently ordered ballscrews, rails, mounts and linear bearings from ebay so I guess I've got to get started.
Here is a couple of pictures of the proposed design.
http://www.cnczone.com/forums/attach...1&d=1242593418
http://www.cnczone.com/forums/attach...1&d=1242593458
The base and gantry will be welded steel. The z axis mount and router bracket will probably be aluminium although I may try mdf as a prototype.
The machine will have x axis travel of 600mm, y axis travel of 490mm and z axis travel of 170mm if I stick to this design.
I have tried to keep the design as compact as possible to reduce moments on the gantry.
Could you guys please have a look and offer any criticisms before I start cutting stuff up.
The three ballscrews are not shown but they are all 16mm dia 5mm pitch.
I could do with some with selecting the right motors too.
I hope to be able to upload the sketchup file to my webspace soon so if anyone wants to modify it they should be able to.
Many thanks
Paul
ID:	81491   Click image for larger version
Old 05-17-2009, 05:30 PM
Kipper's Avatar
Kipper is on a distinguished road
Looks better than some of the commercial offerings! Get it made then.
Keith
Old 05-18-2009, 06:58 PM
FandZ's Avatar
FandZ is on a distinguished road
Nothing looks bad on it, just need to add on those motor mounts and ball screws to get an idea on how you plan to drive it.
Old 05-18-2009, 11:12 PM
bad bearings is on a distinguished road
It is a nice and simple design. On the gantry, are you using recirculating balls or bushings? There are some decent plastic bushings out there--Igus makes some. They work well with sawdust and tolerate misalignment better than balls. Also, for a router timing belts may work better than ballscrews--again they tolerate sawdust and dirt. There was an article in Machine Design about a year ago about a way to use timing belts with a differential carriage--sort of like a Chinese Windlass. This way you can get a large gear ratio without gearing down the input shaft--similar to a ballscrew. The article claimed that the inventor had obtained resolutions and repeatability similar to a ballscrew. Good luck.
Old 05-19-2009, 02:16 PM
Thanks for the replies.
I have to be honest, I don't know what sort of bearings/bushes I'm getting. I ordered a bundle deal from ebay which was 3 pairs of rails (12mm 16mm & 20mm), 2 bearing mounts for each rail, 3 ballsrews with nuts, mounts and couplings. All coming from China. According to the order tracking, the items are currently with customs. No doubt I will get a hefty bill for duty and VAT but it should still be a good saving.
Thanks for the info on the timing belt but as you can see, I'm pretty much committed to using ballscrews now.
I can't wait to get started properly. I will of course post my progress on this forum.
Old 05-20-2009, 04:46 AM
Kammo1 is on a distinguished road
Hey Paul that looks like it will be a fantastic machine bro,where are you based in the UK I'm in Nottingham
Old 05-20-2009, 04:55 AM
Hi Kammo1
I am in Rochester, Kent. I'm hoping to find some cnc enthusiasts near me so I have someone I can call on when it all starts going wrong.
The bits have arrived today. They look great, only problem is the rails and bearings for the z axis were not in the delivery? An email is on its way to them.
Old 01-22-2010, 12:50 PM
Well, I did it.
It took about 5 months of grabbing the odd hour here or there but it works.
here are a few photos.
And finally, here's a video of it working
Old 01-22-2010, 02:52 PM
Thazul is on a distinguished road
Nicely done, Grats on the machine!
Old 01-22-2010, 04:21 PM
Phife is on a distinguished road
Looks great! did you go with a MDF Z axis?
That Ball in Cube looks fantastic, I'd love to try something like that, Willing to share some more details on how it was done? share the model?
  #11   Ban this user!
Old 01-22-2010, 05:57 PM
FandZ's Avatar
Hey hey, congrats! it really came out great. What are your IPM and all that?
  #12   Ban this user!
Old 01-22-2010, 08:17 PM
marzetti is on a distinguished road
Nice machine! Just wondering what cam software you used for the ball-in-box and where you came up with the model.
O-ring groove design - comments please octathorpe General Metalwork Discussion 8 06-23-2008 06:23 PM
Need comments on design concept please Jester966 Benchtop Machines 5 02-25-2007 07:12 PM
Proposed new machine for comments mark.browne General Metal Working Machines 0 07-23-2006 03:59 PM
Comments on homebrew design Zach_G General Metal Working Machines 19 01-29-2006 09:27 AM
Comments needed for this design...thx! andyew DIY-CNC Router Table Machines 12 08-31-2004 03:59 PM
