I have a question regarding home switches.... where should the home switch be relative to the limit switch ie in the y axis.. should it be set the same distance back as the y axis limit ? If I have a travel arm mounted on the carrage it should hit limit switch frist swip past it ie...have a small travel distance till it hits y home switch.....? H---L -y axis ..........................+yaxis L ^ ^^{carrage mounted arm}--------------------- please post a picture,,, if you can of your set up... |
| It partially depends on the control software and if you are using steppers or servo's. For steppers, personally I put one switch on each axis, a "Home" switch. For the Z axis I place it at the up end of the travel. On the X (and Y) I place it on the end of the axis where I want 0.0. MACH3 and EMC you can define software limits that once "HOMED" minimizes the need for actual hardware "Limit" switches. EMC you can define that "HOME" switch also as a limit switch for that end of travel. But when you set it up, you have to move away from the "HOME" switch during a HOME operation.
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| Limit should be outside the home switch. The machine can't pass over a limit to get to home, as the limit switch will stop the machine before it can home.
| In my case, I use the home switch as the limit switch! In other words, the same switch is used for a dual purpose! In this case, the limit position is basically the home position. It saves space as I only had to have one switch to do the job and most controllers that I am familiar with will allow this practice.
__________________ Art AKA Country Bubba (Older Than Dirt) |
| as shown below L -y axis ......H.......................L +y axis ................^ .............. ^^{carrage mounted arm}--------------------- |
| Need Help!- Schematic for Limits switches | SPEEDRE | General Electronics Discussion | 4 | 02-21-2008 09:16 PM |
| How to set up limits w/out home switches | bullseye | Mach Mill | 5 | 10-26-2007 05:44 PM |
| Home / Limits switches | borrisl | Shopmaster/Shoptask | 12 | 03-30-2006 09:25 PM |
| The relationship of limit switches to home switches. | MikeAber | General Electronics Discussion | 4 | 11-04-2004 01:28 PM |
| Limits, homing, and relay switches | Bloy2004 | General Electronics Discussion | 3 | 11-24-2003 05:17 PM |
