Old 04-27-2009, 03:22 PM
bradtal is on a distinguished road
Does increasing/decreasing stepper steps increase torque?
Hello All-
Quick question... Does increasing or decreasing the "steps" on a stepper motor change the torque of the stepper? For example, if I have it set at 1/16 steps right now and change it to 1/4 or 1/2 or even 1/1, will the stepper be able to "push" more weight?
Thanks.
Brad
Old 04-27-2009, 04:53 PM
idtkid's Avatar
idtkid is on a distinguished road
It will make it go much faster, but with steppers, greater speed = less torque so nope unfortunately. If you want speed that is the way to go though.
Old 04-27-2009, 05:18 PM
pminmo's Avatar
pminmo is on a distinguished road
Originally Posted by bradtal View Post
Hello All-
Thanks.
Brad
The answer isn't as simple as the question. It depends on mechanics (mechanical advantage and efficiency), motor, power supply and driver and what motor speed range you need. Here is some info that might be of interest: http://pminmo.com/PMinMOwiki/index.p...chanical_Power
At low speeds, a 2 phase on full step driver will give you the strongest pull out torque, but as you try to get it to speed up, that driving method is prone to the mechanical resonance of the motor.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Stepper Skipping Steps skartch General Electronics Discussion 2 10-27-2008 05:27 PM
Half and full steps , current and torque stragenmitsuko Stepper Motors and Drives 1 12-23-2007 05:46 PM
More Speed needed. Bigger Stepper or increase Ballscrew Pitch ? Joey Stepper Motors and Drives 12 11-30-2007 02:07 PM
Stepper motor torque increase roni21702 Stepper Motors and Drives 3 04-03-2006 12:39 AM
Increasing torque bunalmis Stepper Motors and Drives 1 07-20-2005 01:27 PM
