Old 04-24-2009, 03:20 AM
cvriv.charles is on a distinguished road
Some NOOB questions.
Hello everyone. I'm a NOOB.
1: I was checking out this 2.2kw spindle motor on ebay. It says it comes with an inverter. Whats the inverter for? Powering the motor on and off? Changing speeds?
2: With spindle motors are they usually operated(on off chagne of speed) manually or by a computer?
3: Does anyone know of a good place or more with VERY specific details on building a cnc router? A place that will run me though everything I need in detail? That would be great. I read a post somewhere on this site that there's a sticky with info on spindle motors but cant find it. I need information. lots of it.
4: What does runout mean? Or runoff?!?!?!
This is it for now. Thanks.
Old 04-24-2009, 08:13 AM
ger21's Avatar
1) The Inverter provides the 3 phase power that the spindle needs, and also controls the speed of the spindle.
2) Either way.
3)This site. Start reading.
4) Runout is how "out of round" the spindle is.
Old 04-24-2009, 08:41 AM
Is there a huge difference between a 110v and a 220v spindle of the same kind? Maybe power wise?
Runout,... are you refering to the off center spinning of the router bit?!?! I have a regular router and it SERIOUSLY suffers from this. It's so bad I hate using it. It's a fairly new router too. Anyways.
Thanks for the info.
Old 04-24-2009, 10:17 AM
ger21's Avatar
Afaik, the 2.2KW spindles are all 220V? Actually, the Inverters are 220V.
Yes runout would be the bit wobbling. A good quality router shouldn't have much at all.
Old 04-24-2009, 06:22 PM
One of the ebay sellers saud they have 110v 2.2kw spindles. You just have to ask them to see if they have any in stock.
But seriously,... whats the difference?!?!
Old 04-24-2009, 07:21 PM
BobF is on a distinguished road
Watt is a unit of power. A spindle of 1500 watts should produce the same power no matter the input voltage.
When you use a VFD, what you have is a variable frequency drive. If the motor has a native speed of 1725 rpm at 60hz what is the speed at 360hz?
1725 x 360/60 = 10350rpm. At 400hz it would run at 11500 rpm.
If it was 3450 native at 60hz top speed would be 23000 rpm. This is probably what most of these spindles are capable of.
Old 04-24-2009, 07:32 PM
Thank you so much
Lots of CNC questions (help a noob!) *o* DIY-CNC Router Table Machines 11 03-05-2009 04:52 PM
Noob -- machine settings questions flathead CNC Plasma and Waterjet Machines 4 02-06-2008 09:03 PM
Noob questions on buying a CNC mill. Justin F Benchtop Machines 11 05-28-2007 04:01 PM
Noob Lost With Questions, Dont know what I need for DIY. Jeff000 DIY-CNC Router Table Machines 3 05-31-2006 03:30 PM
NOOB Questions studysession General CAM Discussion 14 03-28-2005 11:02 AM
