Old 01-19-2005, 12:56 AM
chas is on a distinguished road
Timing Belts
Does anyone know where one can buy timing belts in Canada.
Toronto would be great!!
Chas
Old 01-19-2005, 09:03 AM
Al_The_Man's Avatar
Any of the bearing supply houses usually carry them. you must have a whole raft of them in Toronto.
Al
Planetary gearhead vs timing belts Swede General Metal Working Machines 4 03-27-2005 08:19 PM
Timing belts for x and y axes (what pitch?) dowling177 Mechanical Calculations/Engineering Design 2 01-27-2005 09:12 AM
Cheap Source for Timing Belts and Pulleys? samualt DIY-CNC Router Table Machines 10 09-10-2004 06:41 AM
Timing belts.....what type do you use? chozo DIY-CNC Router Table Machines 4 08-27-2004 09:19 PM
Timing belts, gears, and ratios samualt DIY-CNC Router Table Machines 11 12-19-2003 07:09 PM
