Old 04-23-2009, 05:26 PM
finishlinewrx's Avatar
finishlinewrx is on a distinguished road
1/2-10 5 Start on Z axis
I currently have Z axis mocked up with a section of 5 start acme that got trimmed off my X axis.
I guess what i am wondering is, will a 387ozin motor dead lift a +/- 25 lbs axis?
Or should i drop to single start screw?
I still need one more anti backlash nut anyway and i have both pieces of screw for either way available. So it is just a matter of what to go with single or 5 start.
Thanks Nick
Nick
I Know I Cant Spell..Don't Remind Me
Old 04-23-2009, 06:22 PM
BobF is on a distinguished road
I think it will.
Of course this advice is worth exactly what you paid for it.
Old 04-23-2009, 06:35 PM
ger21's Avatar
If you look at Nook's acme catalog
http://www.nookindustries.com/pdf/NookInchAcmeScrew.pdf
You'll see that with those screws, it takes 1.7oz of torque to lift 1 lb, so about 43oz to lift 25 lbs. Now, keep in mind that this would be slowly lifting. I don't know how to calculate what torque you'll need to accelerate quickly, but it seems like it would work fine.
grahamshere is on a distinguished road
It works fine with mine, have no problems. Im using 4 start 8 tpi witch is basically the same. Graham
Old 04-23-2009, 07:54 PM
So there is no need to add a couter balance or spring then?
Just turning it by hand it goes down very easy and up and quite a bit harder but i can still rotate the screw with a few fingers compared to the X and Y that are pretty much balanced both ways.
I know it is due to weight, i was just woried about it being to much.
Nick
Old 04-23-2009, 09:00 PM
johnmac's Avatar
johnmac is on a distinguished road
When the machine is shut off the Z will drop. Its called backdriving. Yes, you can use a spring to counterbalance it.
I have a ball screw on my Z and it dies the same thing. Try a long spring, like the kind used on screen doors.
Set the spring tension so the Z motor has to push the router down and the spring lifts it up. Then you don't have to worry about backlash!
John
Old 04-23-2009, 09:09 PM
My machine has a Milwaukee 5625 router on the Z. This is one of the heaviest routers I think you will find. My screws are 1/2 -8 2 starts or 4 tpi. I have no back driving or issues lifting. Motors are 305 oz in.
Old 04-23-2009, 09:55 PM
johnmac's Avatar
The 8 TIP 2 start is about the limit for screws that don't back drive. It would be my choice for the Z axis.
John
Old 04-24-2009, 01:01 AM
I don't think there is a problem there, when the motors are on its not going to drop as long as the couplings are tight, I have yet to have any problems.
Graham
Old 04-24-2009, 06:27 PM
sweckard is on a distinguished road
I have the same screw.
I have the same screw and approx. +25 lbs for the z-axis with a 420 oz-in stepper. The motor handles the weight with ease and I don't see any need for a counter balance or spring. Also I have none to hardly any drop when the motors are shutdown.
Sweck
  #11   Ban this user!
Old 04-24-2009, 09:54 PM
Alright thanks! I'll just leave the one I have in there and give it a shot.
It will be easier with all the same tpi everywhere anyway.
Nick
Need Help!- Can spindle start when you hit the Z-axis button? moldcore Milltronics 2 04-26-2009 08:14 AM
1/2-8 8 start ACME for 8' axis? Rhodan Linear and Rotary Motion 5 04-23-2009 07:35 AM
acme 2 start rod vrs. gear up box on z axis drummer 1 Linear and Rotary Motion 2 02-07-2009 06:38 PM
How to start 1-Axis really simple design Timbersmith DIY-CNC Router Table Machines 31 02-05-2008 07:01 PM
Y axis inhibited at start-up Toymanf Mach Mill 3 11-10-2007 03:30 PM
