Old 04-23-2009, 11:48 AM
nikodell is on a distinguished road
My initial drawing for a steel gantry machiene.
I was going to build a Joes hybrid but it seems I can do a steel table foe less than 25% the cost with surplus steel. This is the initial table top drawing, I will continue to lay out gantry drivers ect. tonight when I get home. Any input on the initial design would be great. I am thinking it might be nice to get the motors out of the way under the table but that would require timing belt, any thoughts on this? Thought is 1 short belt on either stepper + belt connecting the 2,"this is with dual screw drives.
Basic idea:
Initially use of hobby level steppers and router + ability to upgrade to industrial level duty at later date.
LoL cant edit tittle.
Old 04-24-2009, 10:00 AM
next step
Busting the rust off of Autocad and got a start on a rough 3D model to plan the mechanics on. I need to get the drive system drafted and than I will place base supports. Got to study for finals next week also, but should have plenty of time for the plans.
Old 04-24-2009, 08:23 PM
rowbare is on a distinguished road
Looks like a good base for a MechMate. Check it out at http://www.mechmate.com
Old 04-24-2009, 09:34 PM
Hmm yah similar but its a basic table so far. I like the Mechmate rack and pinion but it looks like they are using 10/1 gear reduction steppers, the ones I found on the forum are like 250 a piece, maybe I jumped to quick on electronics?? Oooo well this will do fine.
I got the geko 540 keling package with the 387oz motors. I guess it can be an update later if needed. I like the gantry too but think I may do something more like joes hybird for now and keep the mass lower for the 23's I am happy to see the 10/1's will work with my 540 if I decide to change it out in the future.
http://catalog.orientalmotor.com/ite...=prod&filter=0
I will have a sturdy table to base off of.
Old 04-24-2009, 09:40 PM
Any idea on what the rack and pinion gears would cost? 7' on each side
Old 04-26-2009, 01:30 AM
Not a lot done on the drawing today "homework and cleaning the shop", it was more of an Autocad refresher, did play with my thought on the gantry to help visualize how I want place the drive screws. I am thinking of pushing the lower 2 wheels closer togather to give them room from the base legs.
Name:	NickCNC3 Layout1 (1).jpg‎
Old 04-26-2009, 10:41 AM
My electronics show up tomorrow, it will be hard to study when I can have fun figuring out this stuff.
Name:	Cleaned up a bit.jpg‎
Old 04-26-2009, 12:21 PM
oldhack is on a distinguished road
get them from mcmaster carr. about 200.00 U.S. dollars for a 4x8 table
Old 04-28-2009, 08:39 PM
Well got my Gecko 540, limit switches, and E-Stop but no steppers or power supply, they are not shipping till the 5th or so? Anyhow I started putting my computer together.
Gigabyte GA-7VRXP
Atholon XP 2000+
1 GB memory
Ubuntu + EMC2
17 flat screen Dell crt
and some old slow hd, could this be a problem?
Old 04-28-2009, 08:52 PM
FandZ's Avatar
FandZ is on a distinguished road
I Don't think so. The system requirements to run a cnc machine are pretty low. There are people running cnc's with sub ghz cpu's and 256mb of ram.
  #11   Ban this user!
Old 04-29-2009, 12:31 PM
jsheerin's Avatar
jsheerin is on a distinguished road
If you move your legs in a bit from the corners, you should get less sag in your horizontal beam. I forget what's ideal - might be 1/4 of the length in from the ends, but if you look up truss or beam design, you might be able to find something that talks about this.
  #12   Ban this user!
Old 04-29-2009, 02:13 PM
I actually plan on putting some bracing in the base going to that center 2x2 horizontal, I am just on hold on the plan for a bit. but that is a good thing to consider. I also may go look and see what other steel sections I can find, I am hoping that I can get some 2x6 sections which should resist flexing more.
Ok I was looking at wiring the motors now 4/22 should be good I hope. This is what I am looking at.
http://www.jameco.com/webapp/wcs/sto...ductId=732452&
Steel Gantry Wood Router gavztheouch DIY-CNC Router Table Machines 17 04-21-2009 02:11 PM
Newbie- New and looking for initial help rolljordan Want To Buy...Need help! 0 10-24-2008 06:51 AM
Need Help!- converting imported part drawing to mold drawing msomerville BobCad-Cam 6 08-29-2008 06:56 AM
How do you set the initial Z Height? Normsthename CNC Plasma and Waterjet Machines 2 12-02-2007 05:01 PM
1st Machine, Steel ,Overhead Gantry bradodarb CNC Wood Router Project Log 4 10-18-2006 02:05 AM
