what is consider low backlash for gear box? 5 arc-minutes backlash or less my other question is if you made a diy belt gearbox 5:1 or 10:1 what kind of backlash would be typical for this design...assumming it was made with milling machine.. an tolenace where kept tight. |
| Some of my books say 6 arc minutes for ratios from 3:1 to 10:1 and 10 arc minutes for 16:1 to 100:1 (more gears involved). A belt drive with timing belt may be comparable, depending on the static friction of the load being moved, and how much it stretches the belt upon reversing. I've used belt drives on knee mills without significant problems traceable to the belt stretch versus nut lash, etc.
| Basic Bevel Gear - Milling a valley for gear teeth | ngr1 | General CAM Discussion | 10 | 04-05-2012 09:55 AM |
| Zero backlash worm gear idea. | ynneb | Mechanical Calculations/Engineering Design | 14 | 07-31-2009 12:25 PM |
| Backlash or motor tuning problem? How do I test for backlash? | Brian Queen | Mach Mill | 8 | 03-10-2008 03:35 PM |
| Problem- Wacko gear backlash (or not)???? | IQChallenged | General CAM Discussion | 6 | 01-31-2008 08:00 PM |
| gear backlash | phil spanner | Mechanical Calculations/Engineering Design | 2 | 09-08-2005 08:38 AM |
