Old 04-21-2009, 07:09 PM
Xnaron is on a distinguished road
V-Carve chatter
Anyone know how to get rid of vcarve chatter? This is my first vcarve on my Joe's Hybrid.
1/2" 90 deg v carve bit
20,000 - 22,000 RPM
100 IPM feed rate
acceleration set at 15 in Mach
material 5/8" MDF
ID:	80109   Click image for larger version
ID:	80110   Click image for larger version
ID:	80111   Click image for larger version
ID:	80113   Click image for larger version
ID:	80114   Click image for larger version
ID:	80115   Click image for larger version
Old 04-21-2009, 07:11 PM
ger21's Avatar
Are you cutting it in one pass?
Old 04-21-2009, 07:15 PM
I generated the toolpath with vcarve pro using the vcarve toolpath included with the demo file for the bullshead vcarving.
It is
0.25" pass depth
final pass stepover 0.01" 2.0 %
clearance pass stepover 0.1" 20%
Old 04-21-2009, 07:16 PM
HuFlungDung's Avatar
Moderator
Perhaps all you need is to take a roughing pass first, then a finish pass maybe .01" deeper.
It could also be due to a dull cutter: if it takes a bit of 'push' to get it to cut, it will deflect momentarily, then hog in. It may take some tool shopping to find the ideal tool for a router doing V carve.
Old 04-21-2009, 07:19 PM
harryn is on a distinguished road
Hi, nice work.
I am just guessing here, but it looks like there is a general vibration as it shows up in every cut and direction of cut.
My seat of the pants guess is that the router mounting plate is vibrating - sort of like a tuning fork. Try stiffening up the mount plate with a gusset of some kind to the vertical plate on your Z axis. The dust collector hanging out on the end is probably not helping but might be ok. Mounting it off to the side is potentially a benefit.
edit - well, I see now that the real experts have weighed in with better answers. Still, perhaps try running it without the dust collector to see if it makes any difference.
Old 04-21-2009, 07:27 PM
Thanks I appreciate the advice...this is the first vcarving I have done so have nothing to compare it to.
Edit: I noticed you are in Canada...are you close to Edmonton ?
Old 04-21-2009, 07:29 PM
Originally Posted by harryn View Post
Hi, nice work.
Very good point...I used to have it tied up the z-axis but forgot to put it up again after I recently had it apart. I should trycutting one without the dust shoe attached. I could try different RPM settings as well.
V Carve pro and Busellato JET 3006 Vectric 23 03-07-2008 04:10 AM
Problem- v-carve in mm serocco Vectric 5 02-13-2008 05:13 AM
V Carve tangocc35 Joes CNC Model 2006 4 10-17-2007 03:18 PM
V Carve possible changes Brian P Vectric 2 09-11-2006 03:32 PM
ImageCarve and V-Carve... jdbaker General CNC (Mill and Lathe) Control Software (NC) 3 01-08-2006 10:09 AM
