Old 04-17-2009, 11:09 PM
eloid is on a distinguished road
how to understanding basic g code?
I have been looking around at different site and have not found any
good sites to help explain basic g code..programing. Looked a mach web page
but need more examples . is there a intro thread of g code ?
Old 04-17-2009, 11:27 PM
Here is a thread that has a link to an online course:
http://www.cnczone.com/forums/showthread.php?t=15358
Someone will also probably come on with a link to some books by Peter Schmid (Did I get the name correct?).
Old 04-17-2009, 11:43 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
thios is a good site which explains the code using examples http://www.cncezpro.com/gcodes.cfm
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 04-18-2009, 01:43 AM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
It is a pretty good reference but needs some editing in the Lathe Dept.
Most Lathe guys do not use G54-G59, they usually use the Work Shift.
G18 will be the only work plane you will use unless you have a True Y Axis and Live Tooling. You will also have a C Axis in the Spindle.
G74 is a Face Grooving Cycle that doubles as a Drilling Cycle.
G90 is a short Rough Turning Cycle that is programmed like a G92.
G91 isn't used at all because you would use Parallel Axis to X and Z which would be U and W.
The Control sees U and W and knows it is Incremental.
Other than those it looks pretty good.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 12-19-2011, 08:56 AM
mousongie is on a distinguished road
Hi guys!,
I strongly recommand you a book " CNC PROGRAMMING HANDBOOK " by Peter Smid.
Old 12-19-2011, 09:22 AM
DonFrambach is on a distinguished road
Originally Posted by mousongie View Post
Hi guys!,
I agree!!!!!
Need Help!- PICStep/Linistepper/AVRSTMD Code in C or BASIC joprinz Open Source Controller Boards 3 03-29-2009 09:50 AM
Need Help!- Understanding Toolchange in Code Constructor bk1955 EdgeCam 2 11-12-2008 07:17 AM
Need Help!- Basic CNC code question from a novice piaengr CNC Plasma and Waterjet Machines 4 07-18-2008 11:55 AM
Basic G-Code Question Tazzer G-Code Programing 11 05-18-2008 09:21 PM
Understanding G-code ... or not! geoff p G-Code Programing 4 01-01-2006 01:46 PM
