As for leadscrew choice, 1/2-10 Acme is a pretty universal leadscrew. It works very well on many homebuilt machines. And still gives you a theoretical resolution of .0005. It's cheap, too.
__________________ Gerry Mach3 2010 Screenset http://home.comcast.net/~cncwoodworker/2010.html (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Last edited by ger21; 01-17-2005 at 10:00 AM. |
| Twas an example. I suspect that most everyone knows or has experienced a stepper system that does not move as accurately as you expected. What causes these problems...the stepper encounters a condition where it is not able to move a step these conditions can be that the required torque to move a step exceeds what the stepper can provide, you are attempting to step at a frequency that the stepper, the hardware or software cannot attain. Let's assume that you've requested your stepper to ramp up from a dead stop to some maximum speed of say 16 inches per second (so with our 1/2 10 ACME screw and the 1.8 degree stepper that would be 16 inches per second X 10 threads per inch per revolution X 200 steps per revolution = 32000 steps per second). Given this a parallel port without interference from Windows could handle this, no problem for properly written software, the ACME at 10 revolutions per second is 600 RPM, which shouldn't be a problem, if the stepper has the torque to overcome the friction that the nut is placing on the ACME due to it's load and the normal friction between the nut and ACME screw then we don't have a problem. We encounter difficulties when we ramp up to full speed and then ramp down to home into a movement of only 0.100 where we are going to change direction. So, software attempts to do this is several ways (ramp up speed, ramp down speed, compensation factors....those of the little things that we feed the software when we see something that is not correct, or to compensate for the diameter of the cutting tool or the know inaccuracy of the leadscrew, etc. In reality we use many things to compensate (or mask) anomalies...I could go on, but I'm hungry. Hope this helps! |
| I'm guessing you meant 16 inches per minute? Which is only 160rpm, right?
| Well then it's 9600 rpm for 16ips. Or are they 2 different examples?
So 16 inches per second X 10 Revolutions per inch x 60 seconds per minute = 9600 Revolutions per minute. This is beyond the theoretical limit for this size of ACME screw with a 20 lb load by about 1000 RPM. As you all have seen write down everything, draw pictures and check the mathematics and the assumptions. Anyway, you can go to http://www.nookindustries.com and look at the ACME screws and at the bottom there are links that will allow you to determine critical speed of an ACME screw, you can even calculate the required torque needed to move loads. I hope this helps! |
#10
And at least 3x the useable speed of a stepper motor.
#12
| Jan. Most steppers are 200 steps per revolution. So, if you have, for example, a 10 turns per inch leadscrew, the motor turns 10 times to move 1 inch. 10 * 200 = 2000 steps per inch. 1/2000 = .0005 per step
| Ballscrew Basics | Swede | Linear and Rotary Motion | 101 | 04-16-2012 08:09 PM |
| Lead screw whip | spalm | DIY-CNC Router Table Machines | 3 | 05-24-2005 02:04 PM |
| Alternate Lead Screw Mounting Idea | Jay C | Mechanical Calculations/Engineering Design | 4 | 02-20-2005 01:32 PM |
| How to machine a 56 Rockwell lead screw | bgolash | General Metalwork Discussion | 6 | 12-05-2004 03:25 AM |
| Cheap UK Lead Screw, but is it any good? | MrBean | DIY-CNC Router Table Machines | 3 | 02-15-2004 12:59 AM |
