| I'm in the process of getting materials together to build my first CNC router. This first machine is mostly proof of concept and a learning experience. As such, I'm putting it together from anything I can find laying around my gararge. Okay, here's the question. I have a box of brass bearings that appear to be for sliding screen doors. They are about an inch in diameter and have a half circle bearing surface and no detectable play. I'm thinking I could put them on the top and bottom of a rail with a matching bearing profile. Has anyone tried this? Think it'll work? Thanks, |
-marc |
| The bearings have too much slop for a CNC application. I've tried them for proof of concept and returned to the tried and true skate bearings or equivalent. The patio door bearings are still on a mat-board cutter that I made, but only on the X axis which is locked into position while the cut is done along the Y (which uses skate bearings on conduit). Cold-rolled-round rod is used as the track for the door bearings...1/4" I think? Anyway from my experience they are not worth the trouble. They did look like a good idea though didn't they A cheap and dirty table I made... http://solsylva.com/cnc/cnchome.html Last edited by sol; 01-16-2005 at 03:55 PM. |
| Thanks for the feedback. I don't know if this will make any difference, but I went to Ace hardware today and figured out that the bearings are for sliding GLASS doors, not screens. The ones for screens are a bigger diameter, thinner, and do have lots of play. I think I'll hack up a rail using rod like you mentioned on some sort of support, take a pic and put it up here for critique... |
| Using your CNC Mill as a CNC Lathe | lstool | Knee Vertical Mills | 10 | 08-02-2010 12:06 AM |
| Making money with CNC | Johnuk | CNCzone Club House | 26 | 12-13-2009 10:46 AM |
| Beginners CNC Advice | UKRobotics | General Metal Working Machines | 5 | 10-08-2009 11:10 AM |
| Newbie to CNC world | HighOctane | DIY-CNC Router Table Machines | 6 | 01-25-2005 01:58 PM |
| The start of a big CNC project... | UKRobotics | General Metal Working Machines | 10 | 09-30-2004 05:34 PM |
