Old 04-15-2009, 06:49 AM
groomden is on a distinguished road
baltic birch questions about chipping
hi,
i'm trying to route out some 1/2 inch baltic birch at 80in/min with a 2 flute upspiral solid carbide 1/4 inch bit. even with ramping, i'm getting a little tear out. i've got my router spinning at about 75% of its juice and making passes with a .2 inch depth. its a porter cable 690.
does anyone with more experience know if i want to speed the bit up, slow it down, dig deeper or perform some third operation i don't know about yet? any input is mucho appreciated.
thanks,
dennis
Old 04-15-2009, 08:09 AM
ger21's Avatar
If you cut across the grain and are just trimming a small amount off the edge, Baltic Birch will chip badly. make sure you leave material on the outside of the bit when crosscutting. If that doesn't help, you'll need to switch to a downcut spiral.
Old 04-15-2009, 10:48 AM
jsheerin's Avatar
jsheerin is on a distinguished road
Hi Gerry,
I'm planning a future project in baltic birch. Would you always use a spiral bit as opposed to a standard straight blade router bit?
Thanks,
John
Old 04-15-2009, 12:43 PM
ger21's Avatar
If cost is no issue, then yes, I'd always use a spiral. At work, in our CNC, we only use spiral bits, with the exception being indexable insert cutters. Spirals allow you to cut much faster.
Old 04-15-2009, 05:31 PM
BobF is on a distinguished road
If your setup will allow it, you might try climb milling.
Baltic Birch ply + MDF build, which material for which part nicanor76 DIY-CNC Router Table Machines 6 06-25-2008 06:21 AM
Need A Quote- 3" Baltic Birch plywood disks gmed Employment Opportunity 19 05-12-2008 09:17 PM
RFQ: pieces of 0.5" baltic birch plywood in LA gmed Employment Opportunity 2 09-03-2007 04:27 PM
trouble cutting Baltic Birch carguy327 WoodWorking 4 06-13-2006 12:22 AM
Cutting Baltic Birch with CNC router..which bit? carguy327 WoodWorking 4 03-17-2006 08:08 AM
