| Yes. But since you left out all of the rest of the information needed, I can't go much further.![]() That being said, it would first of all depend on how you are generating a signal that tells what the amps being drawn are. If it is an analog signal, you could add a board that allows ananlog input and maybe create a new screen to display the information on. I will be looking at doing this on my dspmc/ip controlled machines. Mike
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| looking at implement this the most cost effective way.... vai lem, shunt or analog signal etc... doors wide open for now need ideas
| Hi eloid, What make of drive do you have? many industrial drives have a current monitor analog output. If using a gecko drive or similar, you may have to use a shunt or something to get a current value. On my dspmc driven machine, I have 8 analog inputs built in, so its pretty straight forward to make this work.
| CNC machine monitoring | CBNDude | General CNC (Mill and Lathe) Control Software (NC) | 1 | 12-29-2011 06:46 AM |
| New Machine Build- Does the G203v Driver still allow the stepper to draw current | Spitfire | Gecko Drives | 4 | 06-13-2008 03:52 PM |
| How to determine actual current draw for a servo | bgolash | Servo Motors and Drives | 8 | 02-01-2008 01:32 PM |
| 3 Phase Current draw??? | bherr | Bridgeport and Hardinge Mills | 3 | 08-06-2007 03:16 PM |
| gecko 210: low current draw? | anthony | Gecko Drives | 2 | 05-28-2005 02:19 AM |
