Old 04-06-2009, 09:11 PM
diycnc is on a distinguished road
ball screw supplier
what would be a cost effective ball screw supplier? i am looking for approx 16mm 10mm or larger pitch by 2500mm location is Ontario Canada
Old 04-06-2009, 09:58 PM
Hirudin's Avatar
Hirudin is on a distinguished road
Try http://stores.ebay.com/linearmotionbearings
I don't think your post is clear, but be aware that 2500mm is very long for a 16mm diameter screw.
http://www.google.com/search?q=site:...e.com+whipping
Old 04-07-2009, 05:16 AM
your right i should probably go with bigger. the ones for my y axis are 16mm but only half the length.
maybe i should get 25mm screw for x. if i went higher pitch i could just run the screw off a belt and greatly reduce the chance of it whipping.
Old 04-07-2009, 01:28 PM
texasjungle is on a distinguished road
ball screw supplier in ontario
Novakon.net they can supply upto 2 meters 16mm and 20mm dia.
Ball Screw canadian supplier eloid DIY-CNC Router Table Machines 2 02-02-2008 06:20 PM
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
Best Ball Screw supplier for Tri-power? bherr Shopmaster/Shoptask 20 10-15-2006 01:04 PM
Lead Screw Supplier Ed Williams Linear and Rotary Motion 1 04-23-2006 07:36 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
