Old 04-06-2009, 10:15 AM
Truss-rod is on a distinguished road
Bought some cheap steppers, can't get them to turn.
Hi all, I bought some cheap steppers, (if they are steppers). They are Molon model # LMO-6360-1. They were $.95 at a surplus store. They have 4 wires; a red, a white, and 2 black. I hooked 'em up to a univelop board with a computer power supply, and tried to test them with VBstepper. I used the 5v for the board power and a 12v for the motors. when I hit the start botton the motors just lock up, get real hard to turn them by hand. They don't jitter or get hot, just stiffin up. Any ideas what I'm doing wrong?
Any help much appreciated.
Old 04-06-2009, 10:53 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
The steppers are functioning as they should be. Steppers DO lock up at rest. Now you just need to send them some step and direction signals to make them turn.
CR.
Old 04-06-2009, 11:49 AM
Whoops, I'm using VBStepdir in xp from stepperworld.
I understand, so when I hit start and the counter starts rolling, shouldn't the motor start turning and the rate selected? Thats when they lock or rest. When I stop the cycle the motor frees up like there's no power to it.
Old 04-06-2009, 11:57 AM
Sounds like step/direction signals are not making it to controller. Make sure you are using a "straight thru" parallel cable. Check in bios that PP is activated and software has correct PP address.
CR.
Old 04-06-2009, 12:04 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
are you using the stepperworld boards , if so it should work fine ? if not then scroll down the link and connect the same as shown for kcam http://www.stepperworld.com/pgSoftware.htm
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Need Help!- Steppers won't turn marvfrankel Bridgeport and Hardinge Mills 3 04-26-2008 08:54 PM
Steppers Only Turn 1 way twistedfuse Mach Mill 2 06-17-2007 03:13 AM
How to turn cheap tablesaw into woodworking dream ZipSnipe WoodWorking 8 04-11-2007 07:54 AM
Bought a Turn-Key plasma: What should I accept for quality? scorpion CNC Plasma and Waterjet Machines 27 03-19-2007 02:15 PM
Cant get steppers to turn bigvinney General CNC (Mill and Lathe) Control Software (NC) 10 04-24-2006 08:22 AM
