Old 01-10-2005, 07:56 PM
Losos is on a distinguished road
Rails to bearings to carriage to... drive system?
I feel like an idiot... I'm confused on what seems to be the most essential component of a cnc machine: connecting the drive system to the part you want to move! What are the steps and components involved in connecting the carriage to the drive system? (explanations specific to screw driven, belt driven, R&P, ... and/or all the other drive systems out there would be great)
Old 01-10-2005, 09:06 PM
Hobbiest is on a distinguished road
With a screw drive, your carriage would have a nut whose threads match the leadscrew mounted to it. Rack and Pinion would have a pinion gear attached to the motor, on the carriage, with a gear rack fixed to the axis. In a belt config, you would have a fixed motor, with an idler at the extreme opposite end of the axis, the belt would then be attached to the carriage. There are many other ways to do all of this (i.e. fixed lead screw and rotating nut), but these are the most basic.
Stop talking about it and do it already!!!!!
Old 01-11-2005, 12:40 AM
Thanks Hobbiest. I found a pdf that has a good diagram of a simple belt system -- http://www.idcmotion.com/pdf/9002.pdf . You're right, doesn't look like there is much to it. Are there any good online stores that sell prefabed belt-mountable carriages? It seems like every belt system I have seen the designer has machined the mounting pieces on their own.
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
Revolutionary Linear Drive System allanconway2 Polls 21 05-03-2009 08:27 PM
New Obsession.... Moondog CNC Wood Router Project Log 102 10-18-2006 09:52 PM
Drive system question CanopyFx Mechanical Calculations/Engineering Design 4 05-04-2005 03:39 AM
Belts versus Direct Drive bsmith DIY-CNC Router Table Machines 12 06-06-2004 10:09 PM
