Old 04-03-2009, 04:53 PM
Grunblau's Avatar
Grunblau is on a distinguished road
GRÜNBLAU 2'x4' Hybrid
Making some progress on my new project. I thought I'd post a couple pics.
I am trying some linear rail ideas based off of the t-slot extrusions. I will be using v-groove wheels possibly running on actual track, but for now I am using 1/8" flat stock...
You can see here that I drilled and tapped the aluminum spacer using the hole pattern for the track so it could be upgraded later... Try to ignore the shiny Home Depot screws. These will be replaced with some black socket head screws at a later date
Some CAD showing the mounting of the track.... (note the low profile socket heads).
I haven't settled on a specific form of the machine yet or even cutting area but I'll continue to post updates here....
Hopefully this new design will be expandable, I might even retrofit it to my MDF table ...
Last edited by Grunblau; 04-03-2009 at 06:15 PM. Reason: 'I' before 'E' except after 'C'...
Old 04-05-2009, 06:40 PM
BobF is on a distinguished road
Looks good so far.
Old 05-27-2009, 06:33 PM
FandZ's Avatar
FandZ is on a distinguished road
Looking good. I have to say I admire your skill on these projects. I was wondering with the v bearings if there would be any chance of slight back and forth movement due to lateral play in the bearings?
I'm looking to make a new x axis so I'm fishing around for some ideas.
Old 01-12-2012, 09:02 PM
fred_in_mt is on a distinguished road
Grunblau, I just discovered your first build thread (awesome) which led me to this one. No posts in 3 years? Did you finish this one?
Old 01-12-2012, 09:07 PM
ger21's Avatar
I believe he's working on something a little different right now.
Old 01-13-2012, 08:57 AM
Grunblau's Avatar
Only family members and Ger has seen the current generation ....
I will probably post some pics soon as I just got back from vacation in Germany and need to get back to work on it. I am also hybridizing the MDF CNC with some lasercut steel.
Tags
brian oltrogge grunblau
Joe's CNC 4x4 Hybrid joecnc2006 Joes CNC Model 2006 1380 05-05-2012 02:48 PM
Build Log of the Patrick Hood-Daniel 2'x4' 1.2 kit GibbonsRock CNC Wood Router Project Log 38 04-17-2010 11:00 PM
Building a Joe 4x4 hybrid as a 2x4 GibbonsRock Joes CNC Model 2006 39 04-06-2009 11:32 AM
Chris's build log of Hack's 80/20 router ( 2'x4') alwaysready CNC Wood Router Project Log 13 10-16-2008 01:45 AM
hybrid electric blackbeard52 I.C. Engines 1 03-21-2008 08:51 AM
