Old 03-30-2009, 07:08 PM
bkboggy is on a distinguished road
Which parallel cable for G540? Standard or IEEE?
The title says it all. I'm assuming I need a two-male parallel cable because my motherboard and G540 are both females. However, I am unsure whether I should go with standard or IEEE compatible cable.
Old 03-30-2009, 08:21 PM
finishlinewrx's Avatar
finishlinewrx is on a distinguished road
"Straight Through" I do belive IEEE 1284 are point to point.
http://www.startech.com/item/SC10MM-...e-DB25-MM.aspx
Nick
I Know I Cant Spell..Don't Remind Me
Old 03-30-2009, 10:25 PM
Straight through.... so how is it different from let's say a regular one:
Amazon.com: DB25 Male / DB25 Male, 15C, Parallel Data Transfer Cable, 10 ft: Your Store Amazon.com: DB25 Male / DB25 Male, 15C, Parallel Data Transfer Cable, 10 ft: Your Store
or this regular one:
Amazon.com: Belkin F3D508-10 Parallel File Transfer Cable: Your Store Amazon.com: Belkin F3D508-10 Parallel File Transfer Cable: Your Store
or this IEEE:
Amazon.com: Cables To Go - 06104 - 10ft IEEE-1284 DB25 M/M Parallel Cable: Your Store Amazon.com: Cables To Go - 06104 - 10ft IEEE-1284 DB25 M/M Parallel Cable: Your Store
Old 03-30-2009, 10:30 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
NONE of the above! You want 6 ft or less. Like the one at the bottom of this page:
http://kelinginc.net/CNCPackage.html
CR.
Old 03-30-2009, 10:43 PM
CR.
Your prob right but i was under the impression that max safe lenght was around 10-12ft. I have even heard up to 30'
Example>> http://www.connectworld.net/cable-length.html
Parallel Cables Length Limits
Older style Centronics parallel cables, can rarely be more than 15 feet long and still operate correctly, and 9 to 12 feet is a safer limit. The IEEE-1284 can go up to 30feet in length.
Nick
Old 03-30-2009, 10:49 PM
SURE!--For PRINTERS--But NOT for CNC.
CR.
Old 03-30-2009, 10:57 PM
Sorry bk i guess stay under 6'
CR why is this?? just due to the high pulse per second rate?
Ive been testing mine with a 10', but just on the desk. Should i expect problems at the cnc?
Nick
Old 03-30-2009, 10:59 PM
Yep! Much over 6 ft can cause crosstalk problems.
CR.
Old 03-30-2009, 11:12 PM
CR.
I take it you would recommend me cutting mine down to 6' or less?
Nick
Old 03-30-2009, 11:18 PM
Hey--It MIGHT work--If you already HAVE it--Try it! But if you start having problems that's the first thing to change.
CR.
  #11   Ban this user!
Old 03-30-2009, 11:20 PM
Well, just to be 100,000,000,000% safe, I'll go with CR's recommendation and go with Keling's parallel cable.... after all, they know what's up and I got the motors from them. Thank you fellas.
  #12   Ban this user!
Old 03-31-2009, 08:19 AM
They have some nice Home/limit switches, helical couplers and E stop switch also.
CR.
Standard or IEEE parallel cable for G540? bkboggy Gecko Drives 0 03-30-2009 05:28 AM
parallel cable pins nicanor76 DIY-CNC Router Table Machines 8 05-14-2008 06:01 PM
anyone tried USB to Parallel cable? nicanor76 DIY-CNC Router Table Machines 5 05-11-2008 07:09 PM
Parallel Cable Length Cartierusm Mach Software (ArtSoft software) 2 09-11-2007 11:53 PM
Are all Parallel Extention Cable Straight Through? Mr.Chips General Electronics Discussion 2 01-18-2007 07:56 PM
