Old 03-27-2009, 11:57 PM
stepperhead is on a distinguished road
cable and chain drives
hello there ,
I am researching all I can on these machines as I intend to build one soon. I have one nagging question that maybe some of you here can answer. I read the thread all about the differences with all the common screw type drives. I learned that ball screws are the best for no backlash and all the physics involved but what about cable or chain drive systems? It seems to me that a tight cable or chain would not have very much backlash and be a hell of a lot cheaper. do any of you out there have such a drive on your machine? I guess over time the chain or cable may stretch but that could be remedied by a spring and pulley and or a tightener. would this inevitable stretch make the machine inacurate? maybe I am off base here, I am just thinking out loud for ya.
thanks,
mac
Old 03-28-2009, 12:05 AM
ger21's Avatar
acme screws can give you nearly zero backlash for a fraction of the cost of ballscrews.
http://www.dumpstercnc.com/
Old 03-29-2009, 09:03 PM
CalG is on a distinguished road
Ger21
There is a restriction with the referenced components, The "anti-backlash" is only as ridged as the spring force. That is not likely sufficient for machine tool requirements.
Now if the same spring force were applied to indexing opposed nuts, we might have something.
Correct me where I am wrong
CalG
Regards
Cal
Old 03-29-2009, 09:06 PM
ger21's Avatar
What kind of machine are you building? The majority of router builders use the dumpster nuts with no problems. If you are building a machine for cutting metal, then they may not be sufficient for your application.
Old 03-29-2009, 10:27 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
I experimented with chain drive for my set up , and i was quite confident in the performance , it worked great and was a cheap and readily available setup , half way thru the project i found an incredible deal on some lead screws and i put the chain on the shelf , my son and i are currently building him a table and it is a toss up whether we use the chain or we go with a cable system .
the one thing that has to be taken into concideration is the resolution you will have , you will need to gear down some which will gain you torque but at the same time you will need to use microsteppers in order to keep the resolutions low .
you could get a .001" resolution if you use geckos or the likes with ten microsteps and you won't have to gear down too extreme as long as your drive sprocket is kept fairly small
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 04-01-2009, 12:56 AM
ger21, are you suggesting that a cable or chain might be a tighter or stronger design than a spring anti backlash nut. I would guess that a cable may have some stretch in it depending on the metal used and the thickness. It may also stretch over time and use.
the machine I plan on building would be mostly for wood but I would like to also have the capability to do a little aluminum or brass as well.
Just thinking out loud on this.
thanks for the replies.
mac
Old 04-01-2009, 07:41 AM
Weldtutor's Avatar
Weldtutor is on a distinguished road
Chain Drive
Originally Posted by stepperhead View Post
cable or chain. do any of you out there have such a drive on your machine?
My chain driven table is shown HERE.
It has proven to be very satisfactory for the application.
E Chain Bobbyr70 Linear and Rotary Motion 5 01-20-2008 06:09 PM
Roller Chain? rlrhett DIY-CNC Router Table Machines 3 12-21-2007 09:26 PM
cable carrier / chain hpghost Open Source CNC Machine Designs 1 05-02-2007 08:10 AM
Unique Synchromesh Cable Drives from SDP Feature Positive Traction carolpratt Product Announcements & Manufacturer News 0 01-24-2007 10:55 AM
E-chain JerryFlyGuy General Electronics Discussion 9 03-11-2006 11:12 AM
