Old 03-25-2009, 07:30 PM
Drools's Avatar
Drools is on a distinguished road
Aluminum angle and bearings
When making a linear rail using aluminum angle and bearings how far should the bearings over-hang the edge of the aluminum angle?
Old 03-26-2009, 03:18 PM
Jack000 is on a distinguished road
I spent a surprising amount of time thinking about this problem when I was building my machine, dunno why, it seems simple now..
without further ado, voila! my illustrated guide to aluminum angle bearing alignment!
just roll it on the table, if it's flat it's not low enough.
Old 03-27-2009, 12:42 PM
BobF is on a distinguished road
What are your rails going to be? More aluminum angle? I would use steel for the bearings to roll on instead. Pipe?, see the joe2006 forum for good use of pipe and dimensions for bearings.
Old 03-28-2009, 01:16 AM
Steven S's Avatar
Steven S is on a distinguished road
I bought a piece of aluminum angle to do some tests and I noticed that the angle is slightly sharper than 90 degrees. This causes the bearings to ride on their edge rather than on the flat part. Check yours to see if it has that problem.
Steve S.
Old 03-28-2009, 01:47 PM
jam5295 is on a distinguished road
How will aluminum wear?
Old 03-28-2009, 01:55 PM
Drools's Avatar
I'm using 3' 5/8 steel rod as the X axis rails. I sanded and polished them and the result is quite nice. The surface on one has some small pot marks on one side but I can rotate the rod so that the pot marks are not in contact with the bearings.
The hard part is making sure both bearings on the sides are drilled exactly the same.
What will happen if the holes are even a fraction of an inch off?
Old 03-28-2009, 02:06 PM
ger21's Avatar
Clamp a board to the drill press table to use as a fence. That should get them as close to the same as possible.
Old 03-28-2009, 03:47 PM
budP's Avatar
budP is on a distinguished road
Your 5/8 steel rod is not strong enough unless it is supported, it will flex and you will lose a lot of accuracy.
budP
Old 03-30-2009, 10:46 AM
Drools's Avatar
I would imagine Joe's or one of the other builds would have examples of supports needed for the 5/8 rod?
Also I'm looking for examples of DIY adjustment blocks, the kind used to adjust the rods to be perfectly straight and even with each other.
Old 03-30-2009, 01:16 PM
Drools's Avatar
Would the 5/8 rod work for the 2' Y axis?
I found some 1" hardened steel rod that I hope will do for the 3' X axis.
  #11   Ban this user!
Old 03-30-2009, 02:12 PM
Northboy is on a distinguished road
I am very far from expert, I just started my own machine a couple months ago, but I have built many things through the years.
5/8 rod will definitely flex a lot even at two feet. Try supporting the rod and put a dial indicator on it. You will be surprised I think at just how much it will flex with not much pressure at all.
Northboy
  #12   Ban this user!
Old 03-30-2009, 02:52 PM
Drools's Avatar
Maybe I should just use the 1" steel rod for both the X and Y axis.
Take back the 5/8 stuff.
Substitute for aluminum angle in jgro's plans? ljoe1969 JGRO Router Table Design 11 10-10-2010 12:49 AM
Alternative to angle aluminum? rkd JGRO Router Table Design 2 02-09-2007 07:07 AM
New Truck Design - Angle Iron & Skate Bearings datacop Open Source CNC Machine Designs 0 07-12-2006 10:24 AM
skate bearings versus linear bearings paul langwade Linear and Rotary Motion 7 05-29-2006 10:06 AM
Aluminum angle in Inventor spalm Autodesk Software (Autocad, Inventor etc) 3 06-21-2005 03:27 PM
