Old 03-25-2009, 06:19 PM
codevark is on a distinguished road
Solid state relay controlled router
I need some help setting up my SS relay controlled router. I have it so it turns on and off in mach3 but it will turn on and off about 2 times then the software switch won't work. Mach3 says "PWM set to minimum setting". I just need to turn this router(Porter Cable 892) on and off. Can anybody tell me what other things need to be set in Mach3 to make it work.
Expert on solid state relay needed..... planekrazie General Electronics Discussion 7 04-13-2009 10:04 AM
Router 0/1 with solid state relay bigz1 General Electronics Discussion 6 04-24-2008 08:37 PM
solid state relay question aegfurn General Electronics Discussion 9 02-23-2007 09:09 PM
CNC4pc Solid State Relay Board. Smackre General Electronics Discussion 20 05-21-2006 03:19 PM
Solid state relay N4NV General Electronics Discussion 13 05-07-2006 12:19 AM
