Old 03-24-2009, 10:36 PM
gasmasher is on a distinguished road
Guide for determing screw and motors?
I am making plans for my first CNC machine and want to make it desktop size capable of cutting plexi and plastic. I have read a bunch of threads here and am a bit confused on how to determine my drive screw and motor size. Is there some documentation or articles that I can read to get more information?
The plan is to use a rotozip or dremel as my router and I want a cutting bed of about 12" x 12" x 4". I intend to use a 1/4" motion shaft with ball bushing blocks (hopefully the terminology is correct) for support. I really just need to figure out what motors and screw I should target for my first build. Any help is appreciated.
Old 03-25-2009, 02:36 PM
jsheerin's Avatar
jsheerin is on a distinguished road
See:
http://www.cnczone.com/forums/showthread.php?t=8129
Old 03-25-2009, 03:10 PM
That is perfect. Thanks for the link.
Old 03-25-2009, 03:25 PM
shawnc515 is on a distinguished road
how much do you wan't to spend? and do you prefere ball screws or will acme screw do if you wan't ball screws prepare to spend a bit more (at least in my experenc).
ps: sorry about the bad spelling.
Old 03-25-2009, 03:26 PM
sorry did not see some one else reply wile i was typing.
Old 03-25-2009, 05:32 PM
I'm thankful for all replies.
I want to keep the budget for the entire build under $1K. I do plan to use ACME screws to save a bit, but will use a manufactured linear bearing. I'm thinking something like these:
Shaft
Ball bushings
I am still browsing around for shorter shafts since I am not making that large of a cutting bed and assume that I will not be able to cut the hardened steel rods to the desired length.
Here is a rough estimate of my spending plan:
$200 on linear bearings
$150 on screws and homemade backlash nuts
$400 on motors, controller, transformer and case - I like the hobbycnc 4 axis kit (using 2 motors on the X axis)
$100 misc. parts (big red switch, limit switches, wiring, etc..)
I already have roto tools (dremel and a generic roto cutter) and a command PC. I also have the materials to make up the body in plexi for the first revision.
Drill Press Speed Guide, Band Saw Speed Guide zerodegreec General Metal Working Machines 0 02-27-2009 12:12 AM
2 tpi lead screw? What motors? Redline CNC Plasma and Waterjet Machines 5 06-06-2006 07:22 AM
Ball Screw Jacks and Encoded Gear Motors gtslabs Linear and Rotary Motion 2 02-24-2006 09:05 AM
determing thread size for leadscrews WarrenW Mechanical Calculations/Engineering Design 1 10-17-2005 11:42 PM
Kerk Motion RGS (Rapid Guide Screw) Losos DIY-CNC Router Table Machines 0 01-25-2005 10:38 PM
