Old 03-24-2009, 05:53 AM
cjgaus is on a distinguished road
Smile help with circuit layout
I went to the following site and found this little cnc plotter. (the second link is the layout diagram) the main page has the information of the circuit on it.
http://www.luberth.com/plotter/ditwasplotter.htm
http://www.luberth.com/plotter/layout.jpg
I would like to make one and wanted to know if i could change the layout. Instead of using a Centronics connector i wanted to know if it was possible to use a DB25 connecter instead. And if anyone had any layout ideas?
PDF Layout alien_X Rockcliff Machine 2 01-06-2009 05:10 PM
Help with PCB layout tajord General Electronics Discussion 0 05-30-2008 01:16 PM
Layout of centerlines JerryFlyGuy Mechanical Calculations/Engineering Design 222 07-15-2007 08:11 PM
Layout Dye mjarus General Metalwork Discussion 5 12-30-2005 11:06 PM
