Old 03-23-2009, 04:57 PM
dragonstone@sym's Avatar
dragonstone@sym is on a distinguished road
Question DC motors
I have inherited a couple of 24 volt DC motors mith a gearbox attached.
They are from an electric wheel chair.
Is there a way to use these to build the x & y axis ?.
My thinking is to use them to build a larger machine?????
Any help appreciated.
Or is there someplace I can get 3 steppers, controls and software in 1 package?
Have been searching around, finding this and that. will look through this forum some more before I build .
My old Dahlgren engraver is getting too small 12" x 24"
Old 03-23-2009, 10:05 PM
johnmac's Avatar
johnmac is on a distinguished road
While it is tempting to "use what u got", I recommend sticking with steppers or servos.
John
Old 03-23-2009, 10:50 PM
TOTALLYRC is on a distinguished road
Keling has a g540 packge with motors and power supply that is a nice setup, Get a copy of Mach3 and away you go.
The only problem is the budget. How much do you want to spend?
Mike
Old 03-25-2009, 04:53 PM
Looks like the way to go to keep cost@ $1,000
I think with this and Mach I can build a new Machine
Have steel and some materials for table.
Old 03-25-2009, 09:56 PM
If you have the time, start a build log and put a link to it here so I can follow along and help out if possible.
I have learned a lot from the zone and I like to help out when and if I can.
Old 03-26-2009, 12:29 PM
Good idea,
Still just on the paperwork and idea stage now.
Thinking 36 x 48 inches or a bit bigger.
Have 2x2 steel tubing for table frame, some various rails etc.
Had a couple threaded rod @ 6' but is bent and rusted.
will start more on building when warmer weather comes and can move the
motorcycles outside. yay have room in garage again.
Old 03-27-2009, 08:45 AM
jcc3inc is on a distinguished road
A small CNC machine
Sir,
If you will contact me directly, I can send you pix of the 32 x 36 machine that I made. We can always benefit by seeing the approaches that others have taken. I built this as a test bed to tryout my CNC controller.
jccinc-at-owc-dot-net
Regards,
Jack C.
425 oz in motors a bit hot oddatwl Xylotex 5 07-26-2008 10:12 PM
DC motors as servo motors Doug Schwochert Servo Motors and Drives 5 12-26-2007 12:03 PM
495 oz motors lamicron Plasma, EDM and other similar machine Project Log 39 12-10-2007 10:03 PM
No go motors DSL PWR Plasma, EDM and other similar machine Project Log 0 09-05-2007 07:41 PM
stepper motors or servo motors? jprobst Torchmate 3 07-13-2007 05:37 PM
