| Check this site out for info on how to make your own vacuum pods along with recommended pump sizes. http://skalarcnc.netfirms.com/pods.html |
| Hey that timing was perfect, with my review of the Vac-clamp. http://cnczone.com/forums/showthread.php?t=7643 You could use the Vac-Clamp to generate the vacuum and route it to those pods. |
| Could a simple venturi be machined out of plastic that would allow for compressor line and vacuum line connectors? I don't know much about venturis, other than the priciple of them, to design aone that is semi-efficient.
__________________ Mark -------------------------- Check Out My Build-Log(s): http://cnczone.com/forums/showthread.php?t=4716 CNC Router Version 1 [====================] 100% http://cnczone.com/forums/showthread.php?t=39294 CNC Router Version 2 [=|-----------------------] 5% |
| I used this one to make a veneer press. http://www.harborfreight.com/cpi/cta...temnumber=3952 You can get more info on making a vacuum system at http://www.joewoodworker.com Look under veneer press. Basically you need a venturi, vacuum switch, air valve (MAC) and gauge, and some PVC pipe. You can buy a compete kit at the above site, too.
To machine a venturi from plastic is possible, how efficient would it be is another question. The VC4 and VC5 vacuum clamps that we produce have venturis machined to very tight tolerances in very stable and wear resistant materials. To produce a "one off" will be more expensive time wise than buying either one of our clamps or using the venturi from "Harbor Freight" Moderator "ynneb" has produced an independent report on our VC4 single sided clamp and I think that the performance even surprised him. We now have our VC5 clamp which holds itself down. Two sides and two separate venturis. There are many reasons why we believe the Vac-Clamp system to be the better way of vacuum clamping. I will be happy to discuss these points if you wish. Errol @ Vac-Clamp http://www.vac-clamp.com |
| Great idea for the pods. I couldn't help to notice how much the substrate material costs... Too pricey for me. I'm thinking bout making my own out of a plastic cutting board... Think it'll work? And what if both sides had seals then I wouldn't have to be messing up my table. |
| Anyone Know a know of a good book for mill, tool making? | sendkeys | General Metalwork Discussion | 6 | 11-01-2004 09:56 PM |
