Hello All, I am about to start building my first CNC machine today. I am going to build it out of MDF using some of the ideas that I have spotted on this site over the years. My backgound is in Electrical Engineering and metal work. I have decided to build my first router from MDF since I have most of the tools to work with it at home. I will try and get some pics up soon. |
| Here is the base that I built up on the weekend. I plan to just use threaded rod for the motion at this stage. ![]() 16mm MDF with rebate joints. ![]() I will glue the joints later once its all fitting together well. ![]() Here is the complete base. I will mount linear rails and then start on the gantry. ![]() More Pics soon! Expecting some motors and drives this week. I have a controller PC and a case to house it all ready to go. |
I bought a few motors for the X and Y axis off a guy in Hong Kong for $50USD each. Here is a rough spec direct from the add. ![]() ************************************************* HIGH TORQUE CNC NEMA 23 Stepper Motor 28kg.cm HIGH SPEED HIGH TORQUE 28KG-CM (390oz-in) SHIFT DIA 8mm x 20mm LONG Max 3000rpm 1500rpm with half Torque DOUBLE SHIFT AVAILABE FOR ASK 4A PER PHASE 6 LEADS SIZE : 57mm SQ X 118mm LONG Weight 1.6 KG IDEA FOR CNC MILL CONVERSION ************************************************* The drivers are coming from the same guy. I have a 750W PC power supply to use that is capable of 32A @ 12V I plan to use MACH3 on an old P4 that I will mount up in a hard plastic case. More pics tomorrow! |
| Motors and Drives have arrived. I have also built up a touch screen to use on an old 17inch LCD monitor. Cost $140 to get it working. Threw them on a test bench today and the drivers work well. I will take some pics and upload them asap. |
| I will start them off on a 12V system. The drives have inbuilt current limiting that I will set at around 4A. Eventually, I will go to a 72V system (as specified by motor/drive manufacturer) to increase rapid feed rates and torque. I have tested them on a 12V 3A bench top supply (motors unloaded of course) and the performance is acutally reasonable. They are not real good at high speed as you would expect. I will try and get some pics tomorrow if the weather is good here. Most of the basic electronics sorted. Just putting it all in a case at the moment. |
| First time build in Toronto | Tupperwoo | CNC Wood Router Project Log | 3 | 06-19-2008 02:42 PM |
| First time CNC Router Table Build | InControl | DIY-CNC Router Table Machines | 8 | 03-07-2008 12:05 PM |
| another first time build! | multiplex | CNC Wood Router Project Log | 1 | 11-28-2007 09:19 PM |
| DIY - Build CNC for the first time | XenC | Open Source CNC Machine Designs | 4 | 12-21-2006 05:48 AM |
| 3rd CNC ROUTER BUILD time to get serious. | Oldmanandhistoy | CNC Wood Router Project Log | 16 | 02-22-2006 04:41 PM |
