Just thought people at CNC Zone would like to see the router designed and completed last spring for my senior design project at UNC Charlotte. It is a 3-axis CNC Router with a manual Z used for cutting foam and other soft/less dense materials. Motion supplied by ACME threaded rod, brass nuts, and thrust bearings. Power supplied by HobbyCNC 130 oz-in stepper motors controlled by HobbyCNC Pro Chopper Board. G-code is output using Artsoft Lazy-Cam and imported into Mach 3 which is used to control the stepper motors. I am actually hoping to sell the entire project and thought this was the best avenue to do so. If anyone is interested in purchasing the machine or has questions feel free to PM or e-mail me at pharrphaster@gmail.com Any reasonable offer will be considered. You can download a detailed parts list and senior project paper which explains the entire process from start to finish. http://www.zshare.net/download/57355226d09f5712/ - Parts List http://www.zshare.net/download/573551966603a22c/ - Design Paper Lots of photos in addition to the ones below can be found here: http://s191.photobucket.com/albums/z...ign%20Project/ If I could change one part of the design it would be the dremil clamp. When routing denser materials the clamp isn’t sturdy enough causing the tool to dig into the material being cut. All of the aluminum parts were cut out using our waterjet, www.aimsaws.com , and aluminum components machined myself at our shop in Hickory NC and UNC Charlotte Machine Shop. The project was a great learning experience since I have never designed anything this in depth before. A lot of information was absorbed by referring to this website. Machine Specs: 2’ x 3’ Half Inch Aluminum Base ½” Aluminum machine components Modern Linear V- Groove Rollers for X and Y axes McMaster Carr Track Roller for Y axis ¾ - 1 ACME Threaded Rod with Brass Nuts for X, Y, and Z Axes Channel UHMW for Z-axis Thrust bearings for Y and Z axes Hand crank for manual Z-axis Hobby CNC Pro Chopper Driver Board Kit Hobby CNC 130oz-in Stepper Motors for X and Y axes 12V @ 12.5A 150W POWERSUPPLY - MPJA Artsoft Mach 3 Control Softrware via serial port - FREE Artsoft LazyCam Software - FREE ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by xiaphin; 03-20-2009 at 08:02 PM. Reason: wrong e-mail address |
| There were two different sections of senior design. One section was funded by companies that knew exactly what they wanted the project to be. The other section, one I was in, the students had to pay for the project and/or seek funding. My group was lucky enough to get funding. If you are planning to attempt something similar to this and need some parts I have like the board, power supply, steppers, etc. just PM me and I could sell you mine saving you some money. |
| 5-axis control for Senior Project | 5axismagic | LinuxCNC (formerly EMC2) | 3 | 01-02-2008 03:04 PM |
| 3-axis router project | TurboGt | DIY-CNC Router Table Machines | 16 | 12-27-2007 08:42 PM |
| New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter | the__extreme | CNC Wood Router Project Log | 3 | 02-26-2007 02:58 PM |
| Student needs single SIMPLE template cut for senior project | robjaws | Employment Opportunity | 6 | 01-18-2007 11:24 AM |
| Please Help On Senior Research Project | Epik | General CNC (Mill and Lathe) Control Software (NC) | 1 | 12-06-2005 10:00 PM |
