Hi all, I am in the process of putting together a CNC and need some help. I will be using 2 belt drive linear actuators(23" and 30" stroke) for X & Y axis and a ballscrew actuator with 16"stroke for Z axis. Hope someone can help me with the following questions: 1. How to connect a spindle motor design for 220v to the US 110v? 2. What is a recommended KW for cutting wood and aluminium? 3. Do i need brakes for the Z axis stepper motor? Wonder if anyone know where i can find the following: 1. AT Belts and AT Pulley 2. simple opto-isolator breakout board for parallel ports 3. cable guides Thanks Wt |
| I would bet that you could find most of those parts you are looking for on ebay, and for pretty cheap as well. You just need to try different names for them as well to find the deals! Good Luck!
__________________ Check out www.Homegrowncnc.com for free CNC machining info for the average joe! |
| 1) Is it a 3 phase spindle? If so, you'll need a VFD. 2) 1Kw to 10Kw, depending on how fast you go and how much material you want to remove. Probably 1.5-2.2. 3)possibly. Depends how much friction there is and how much weight. An air cylinder might help to hold it up when powered down. 1) www.brecoflex.com http://www.econobelt.com/ 2) www.cnc4pc.com 3)McMaster-Carr page 1502 www.mcmaster.com or make your own http://www.cnczone.com/forums/showthread.php?t=25257
| NEED PARTS | dakotamobile | General Metal Working Machines | 0 | 02-10-2009 12:50 PM |
| Sodick A 350 need parts or parts machine Please!! | deckeldoctor | EDM Machines | 1 | 12-10-2008 07:08 PM |
| new guy in need of parts help | EMCLLC | JGRO Router Table Design | 3 | 01-15-2007 12:28 AM |
| Need a few parts (RFQ) | CNCadmin | Employment Opportunity | 4 | 09-28-2005 12:20 AM |
| RFQ 20 parts | impact | Employment Opportunity | 13 | 04-18-2005 08:20 AM |
