Old 03-16-2009, 10:53 AM
cnc-microcut's Avatar
cnc-microcut is on a distinguished road
My diy homemade router
Hello out there!
I´m new at this forum and i want to show you some pics of my woodworking-machine build.
The first pics were elder, cause the last few weeks in have changed the acme screws and nuts against a belt-drive operated one.
Much more silence an speed. about 12m/min.(480 inch)
Working simensions are X1000, Y600, Z115mm
The spindle was a selfmade one, powered by a 200W DC-Brushmotor.
Enough power for plywood, plastics. Makes 15000RPM.
Today i´ve made a cover for it. Sorry, no pics.
For milling some little figures an statues i´ve made a small 4th axis with 50mm chuck. It´s not finished now, but works.
Improvement never ends, every day a little bit more.
Hope you like it!
Greets
Frank
ID:	77779   Click image for larger version
ID:	77780   Click image for larger version
ID:	77781   Click image for larger version
ID:	77783   Click image for larger version
ID:	77784   Click image for larger version
Old 03-16-2009, 12:52 PM
ZNAK is on a distinguished road
i like your machine!
very clean look!
how it works with belt while hard milling wood or alluminium?
Old 03-16-2009, 02:17 PM
the spindle motor wasn´t build to work in metals, but i´ve chosen brass.
Endmill 6mm
S12000
F300
Stepdown 1mm
and in beechwood
F12000
F1000
Stepdown 5mm
Exakt positioning within 150mm (measured with a digi-caliper), measuring with a yardstick from 0 to 1000mm was optical good too. No backlash, no oil or grease necessarily.
I´m working mostly with foam, so one drop of it ruins my workpieces.
Old 03-16-2009, 04:04 PM
harryn is on a distinguished road
Hi - nice project.
I am also working on a belt drive system and I hope you don't mind a few questions about the belt drive system you chose.
a) Belt selection
- I am still trying to decide on the belt speficiation.
- So far, I am thinking of AT -10 type belt x 25mm wide.
- It looks like you are using HTD tooth profile - could you tell us how wide ?
b) Pulley and shafts
- It looks like perhaps a 12mm diameter shaft with 50 mm dia pulleys ?
Do you see any flexing or are you pretty happy with the sizing ?
Thank you,
HarryN
Old 03-16-2009, 09:52 PM
FandZ's Avatar
FandZ is on a distinguished road
Nice work over all, very clean, and well executed. I especially like your belt driven system. Don't suppose you have any video up anywhere? I'd love to see those belts in action.
Old 03-17-2009, 01:29 AM
@Harry
I´m using HTD belts an pulleys with 5mm teeth and 15mm wide.
Better not to use T or AT-Profile, cause they´ve got a little bit backlash.
I had these pulleys at home, so i take it.
There is a little flexing, but not so much that you cant use the machine für aluminium and brass.
Notice: the machine was made for wood and plastics. I´m mostly using end- and ballmills dia 1.5-6mm and some v-bits for carving.
The shafts are 10mm diameter, made from a brass-rail. (was lying there, anywhere).
The pulleys for the gears are 16/40 teeth, pulley on the belt with 20 teeth.
One turn of the belt-pulley is 100mm.
the steppers are running in 1/40 step = 0.005mm/step.
Very silent, sounds like a servomotor.
@FandZ
I´ve only got this one, first test of the rebuild axis.
Perhaps today i make another one.
I´m coming soon from work, its 7:26am, going to bed.
Old 03-17-2009, 12:52 PM
Wink
Today i have finished the cover for the spindle motor, on top with a little exhaust for cooling. At the back of the plastic pipe is a small slot for the outtaking air.
A new video for showing the rapid moves comes later.
Greets
Frank
ID:	77890   Click image for larger version
Old 03-18-2009, 01:27 AM
Here´s the new video, you can hear the different noises between the beltdrive-axis in 1/40 steps and the z-axis in 1/10 step.
Old 03-18-2009, 02:32 AM
Thank you for all of the helpful information. Nice video.
Old 03-18-2009, 05:59 PM
FandZ's Avatar
Thanks for the video. That's a great build. Your speed seems perfect for the size.
  #11   Ban this user!
Old 03-20-2009, 02:53 AM
indianvirus's Avatar
indianvirus is on a distinguished road
nice machine bro...
tell me sumthing abt spindle...
  #12   Ban this user!
Old 03-20-2009, 12:29 PM
Hey guys,
something new happens, a little bit of "tuning for the eyes". Pimp my router
Also i made a cover for the gear of the 4th axis.
ID:	78061   Click image for larger version
Here is my new homemade router ahmed CNC Wood Router Project Log 8 12-09-2006 12:17 PM
Can an Homemade Router do '3D' Normsthename DIY-CNC Router Table Machines 14 07-13-2006 07:19 AM
Homemade Router nearly complete... rlinscheid DIY-CNC Router Table Machines 2 07-05-2006 08:15 AM
Another Homemade CNC Router southernexplore DIY-CNC Router Table Machines 0 02-18-2006 08:59 PM
And yet another first homemade router Stevenpats DIY-CNC Router Table Machines 1 11-15-2003 05:28 PM
