Old 03-15-2009, 11:56 PM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
Question What Nut will Fit?
I have some Series 25 5010 extrusion and want to bolt a NSK lineal bearing on it.
It seems that the smallest Allen head cap screw that they call out for the series 25 extrusion is a 10/32. And the head of a 10/32 screw is too big to fit into the NSK rail socket.
The two sizes of screws that will fit are M5 and a 8/32 cap screw.
Is my only option making the nuts myself? Or is there a nut that will fit the series 25 allow me to use either the M5 and a 8/32 cap screws.
Hager
Old 03-16-2009, 01:27 AM
jalessi's Avatar
jalessi is on a distinguished road
Post 25-1951 T-NUT
Hager,
Will this work 25-1951 T-NUT?
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 03-16-2009, 02:09 AM
Mr.Chips's Avatar
Gold Member
Originally Posted by jalessi View Post
Hager,
Jeff...
Thanks Jeff
That's exactly what I was looking for.
Hager
Old 03-16-2009, 06:44 AM
Metalmechanic is on a distinguished road
What nut
Mr Chips
I have worked extensively with both linear unit and extrusion shown in your post. Contact Parker-IPS in Massachusetts for all the parts you need. A little pricey. They also have extrusion designed for the linear unit shown. Call 508 832 0085
Good luck
Larry
Old 03-16-2009, 08:55 AM
Mr.Chips's Avatar
Gold Member
Originally Posted by Metalmechanic View Post
Mr Chips
Good luck
Larry
Thanks Larry,
And welcome to the CNCZone. You will like it here.
Hager
Old 03-17-2009, 09:02 AM
PRADEEP R.KHARE is on a distinguished road
SCREWS & NUTS FOR NSK
Originally Posted by Mr.Chips View Post
Thanks Larry,
Hager
AS THIS IS NSK MEANS MADE IN JAPAN MEANS METRIC ALLEN CAP SCREW & NUT M5 ONLY. & YOU CAN GET THEM IN YOUR MARKET.
THANKING YOU
PRADEEP R. KHARE
INDIA
0091 9881747414 MOBILE NO.
prkhare@hotmail.com
