Old 03-15-2009, 08:56 PM
flash319 is on a distinguished road
Spring loading rack and pinion?
May be a stupid question but I work in the automation industry and have yet to see a spring loaded pinion running on a rack. I find many machines on here that have this feature?? Why do people do this on DIY machines? Is it because of alignment issues? Is it a protection device? Why not just have an adjustment for the gear pre-load?
Old 03-16-2009, 05:25 AM
ZNAK is on a distinguished road
in my case it is because of alignment issues))
+ you get no backlash
+ less load on stepper -> you can go faster and more stable at high speed.
Old 03-16-2009, 08:07 AM
ger21's Avatar
Even though the spring is probably not the best method, it's the easiest.
Old 03-16-2009, 08:52 AM
serious routers i think dont use springs, but for hobby it is ok!
Old 03-17-2009, 06:57 AM
keyancnc is on a distinguished road
Rack&pinion
According to me,not only the alignment problem but also to self compensating the wear.But i think that during heavy load pinion may loose some steps.
Rack and Pinion ozturbo Linear and Rotary Motion 3 03-19-2008 07:20 PM
spring loading pinions carlcnc DIY-CNC Router Table Machines 7 12-22-2007 05:49 PM
spring loaded rack and pinion dgalaxy CNC Plasma and Waterjet Machines 4 12-03-2006 11:49 AM
Spring Loaded Rack and Pinion request ty1295 CNC Plasma and Waterjet Machines 1 02-07-2005 11:15 PM
calculatiing pinion size for rack and pinion setup Apples DIY-CNC Router Table Machines 3 05-18-2004 09:36 PM
