Old 03-15-2009, 06:47 PM
margni74 is on a distinguished road
metal versus plastic pulleys
I need to gear down a couple of my motors... I'm specifically looking at getting some of the polycarbonate timing pulleys from SDP/SI.
Are these going to shred themselves into pieces?
The metal pulleys are about 4x more expensive.
Old 04-05-2009, 11:07 AM
Asmordo is on a distinguished road
Interesting question
Hi! (This is my first post. So I guess I'm not a silent lurker anymore ^_^; )
It's my uneducated bet that polycarbon pulleys will stand quite a beating. At what speeds would you be using them at? It would be less likely that a pulley of metal would shatter when going at 20000rpm. But we all have seen what happens to cd's that's also made of polycarbon...
Just kidding though. I have no idea if something similar could ever happen to a pulley made of polycarbon. I'm just venting my opinion a bit. I hope you don't mind!?
But as I'm also planning to buy some pulleys in a couple of months, and they are probably going to be metal, it feels strange to recommenced you buying the ones of polycarbon. The reason why I will buy metal is probably because that's what most machines use that I have seen, so I'm used to the sight (maybe a bad thing!?) Most were old though. Maybe it's more common now a days with polycarbon and other more - in my opinion - exotic materials?! Maybe someone knows.
--edit--
I saw now when I reread your post that you were using the pulleys to gear down your motors. Sorry, I must have missed it. Then it would probably be safer to use the polycarbon pulleys I guess. But I would still go for the metal if it were me. (I love to use more money than I need just to be safe)
Last edited by Asmordo; 04-05-2009 at 11:26 AM. Reason: forgot part of the question
Old 04-05-2009, 01:09 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
you'd shred the belts before you do any damage to the pullies
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 04-05-2009, 06:58 PM
johnmac's Avatar
johnmac is on a distinguished road
The only problem I have seen with nonmetallic gears and pulleys are with set screws. its easy to over tighten, and if they don't crack at the time, they do over time.
John
Old 04-21-2009, 08:30 PM
Thanks for the replies... i went with polycarbonate.. They seem to be doing the trick so far.
Ottawa metal and plastic PsyKotyk Canadian Club House 4 11-02-2010 07:40 AM
Etching on both plastic and metal? squale General Metalwork Discussion 0 11-14-2008 09:37 PM
Ease of use.. GibbsCAM versus Mastercam versus BobCADCAM, etc.? squale General CAM Discussion 4 11-10-2008 05:41 PM
WTB: Spindle motor for wood/plastic/light metal DIY-Guy Want To Buy...Need help! 4 05-12-2008 04:06 AM
Newbie- Plastic: mill versus mold.... leppya Glass, Plastic and Stone 1 02-11-2008 05:56 AM
