  #13   Ban this user!
Old 03-18-2009, 11:46 PM
harryn is on a distinguished road
I know this is wrong, but sometimes I just use liquid soap as a cutting fluid. (home use) It makes cleaning the parts really easy.
  #14   Ban this user!
Old 03-18-2009, 11:50 PM
What is wrong about that? It works!
Just rubbing ordinary bar soap on works also especially for drilling plastics; retract the drill and hold a bit of soap against as it is running then back into the hole.
Cold Rolled Steel Accuracy Zach_G Mechanical Calculations/Engineering Design 13 11-25-2008 08:59 PM
Cold rolled steel, flats or square for use as rails. Apples Linear and Rotary Motion 10 08-09-2008 12:22 AM
VF-2 Cutting 1/4" Mild Steel plate akedward Haas Mills 20 11-24-2007 06:05 PM
Cutting 1" Mild Steel 3DSteve CNC Plasma and Waterjet Machines 14 06-14-2007 04:58 AM
Need to cut 1 x 4 cold rolled steel - Product Review jderou General Metal Working Machines 17 07-06-2005 11:24 AM
