Old 03-15-2009, 03:43 AM
upside is on a distinguished road
Question Will this Router / Mill work?
I am planning on building a router that will work as a milling machine. Will this work or is it hot strong enough? So here's what I have, I made the table out of 3x3x1/8 steel and I am thinking of making the gantry out of the same. It is 50" wide and 24" deep but the side rails are 30" so it can travel 24"
I don't know if you guys ever seen Dave Gingery's books on building "a home shop from scrap" (I'm sure some of you must have!) but that is what I am basing the design for my rails on.
I am adding a picture and zipped dxf file of a rough drawing I did in Rhino but I just downloaded that a couple days ago so I'm not very good yet, but you can get the basic idea. I ended up using a few of my 25 save so I could show you guys! I am using 3/8x3 cold rolled for the rails on the x even though my drawing shows 1/4" The t-slots are going to be made out of 1/4" cold rolled and aluminum(I know, it's going to be a beast!)
I was thinking of making the z axis out of 2x2 steel and making it so I could raise and lower the whole tube with a hand crank and having the head move up and down on the tube via cnc.
I was planing on using timing belts to drive the x and y.
So, what do you guys think? Is it posible? Not strong enough? To heavy? Let me know all the hundereds of reasons why it won't work. Thanks guys.
Old 03-15-2009, 05:15 PM
What size steppers or servos would it take to drive this thing? I am thinking I will put one on each side of the x axis.
Old 03-15-2009, 11:49 PM
FandZ's Avatar
FandZ is on a distinguished road
It looks promising. And I don't think there is such a thing as too heavy of a CNC. How much do you think your Y axis and Z axis will end up weighing?
I'd keep working on your design, you are headed in the right direction.
Old 03-16-2009, 01:29 AM
Thanks. What I meant was would it be to difficult for the motors to push around? It will probably be a couple hundred lbs and I realized I did not really state it clearly but I am not planing on putting any rollers on it, it just slides on the rails. That is for a couple reasons, first because I am broke and can't afford it and second is because I am not sure they would be strong enough to mill steel.
What I mean by it being a mill is that I want to be able to use it just like a horizontal milling machine or vertical. After the machine is done I am going to make a angle table to hold the work, again designed after Gingery's mill only bigger. The head is going to be made like the taig mill and I will probably get a taig motor for it, I will be able to turn it sideways for horizontal milling.
Would it be better to go with steppers or servos for this? I would like to get 500ipm but be able to go really slow for milling. I read that steppers lose power the faster they go which would be ok because I would slow it down for heavier milling. Would two 640oz steppers work for the gantry? I would like to get by as cheap as possible.
Old 03-17-2009, 12:40 AM
Question
I am also wondering how to get the rails perfectly level with each other so I don't get a warp in everything I mill? I don't have a flat object that large to go off of. I suppose a level would do since anything i mill that's that big will be flat anyway. And one more thing I was wondering is how you square up the gantry on a 4ft wide machine?
Need Help!- Will this motor work for CNC router? Ncflatlander Servo Motors and Drives 4 01-07-2009 11:15 PM
Need CNC Router work? Yoche Employment Opportunity 3 04-17-2007 11:44 AM
RFQ - milling work on 1/4" wide tool steel - may need azis mill or right-angle mill pendentive Employment Opportunity 7 01-21-2007 08:56 PM
