Old 03-14-2009, 08:43 AM
SPEEDRE is on a distinguished road
Brain Fart Redux
Well I am sure that this is my issue from the previous post in the Mach 3 forum. But, I think I may want to have this stuff also. Making the ZERO plates is ok, but, where does the wire go, and how does it tell Mach what to do. Can, a gleeping gnome like me ,with no programming or eletronical knowledge do it, Please help. I,m ready to toss all this s##t out the window.
Old 03-14-2009, 09:04 AM
TOTALLYRC is on a distinguished road
Bleepin gnome??????????
You can't be all bad, you made it to the zone.
Are you are talking about a plate to set the Z height, electrically???
Then the answer is yes you can.
Old 03-14-2009, 10:38 AM
ger21's Avatar
Everything you need to know is right here.
http://cnczone.com/forums/showthread.php?t=36099
Need Help!- BRAIN FART ???? SPEEDRE Mach Software (ArtSoft software) 5 04-04-2009 10:51 AM
DRO Redux SPEEDRE Benchtop Machines 3 02-16-2008 08:34 AM
Belt Drive Redux rlrhett Rockcliff Machine 1 02-07-2008 01:00 PM
First CNC fart wildcat Industrial Hobbies (Support forum) 19 12-20-2006 03:05 PM
Having a brain fart, help DACMACHINE Servo Drives 5 05-20-2005 01:30 PM
