Old 03-13-2009, 09:37 AM
plcamp is on a distinguished road
Do youy recognize this profile
Some years back I salvaged some T-Slot extruded aluminum frame from a defunct project we were working on but unfortunately I do not recall the manufacture of the product. If you recognize the attached profile please contact me with any associated information as to its origin.
The product measures 80mm x 50mm
Thanks, Paul Camp
Old 03-13-2009, 12:58 PM
drobertson is on a distinguished road
It looks like something 8020 would put out, but it is hard to be sure. Check out their web ste and see if you canfind a match.
http://www.8020.net/
Good luck.
Doug
Old 03-13-2009, 01:07 PM
SPEEDRE is on a distinguished road
Looks like Bosch-Rexroth profile Alum. extrusion
Old 03-13-2009, 01:56 PM
Al_The_Man's Avatar
In the past I have used something that looks very close, it was made by Item Products, I am not sure if they are still around, I seem to remember they were taken over at least twice.
One of the extrusions was nice as it had galley's running through to pipe oxy & gas through and you just drilled and tapped a fitting where you wanted to exit for multi-torch CNC Gantry.
Old 03-14-2009, 04:16 AM
joejared is on a distinguished road
Thanks, Paul Camp
Google
First hit
Old 03-14-2009, 05:54 AM
Do you recognize this profile
Item products sounds familiar, and yes the extrusion is heavy,rigid and very versatile. At any rate I have 2 60" and 1 72" lengths and I would like to keep everything the same if I need to pruchase more as my router design develops. It's like 'Murphy' change is almost certain to happen.
Paul
Old 03-14-2009, 05:57 AM
Good luck.
Doug
I had researched 8020 prior to this posting, thanks for the feedback
Old 03-14-2009, 06:02 AM
I had researched the Bosch-Rexroth products prior to this posting, and they are similar but not the same. The extruded profile is not really that much of a concern if it's of a different configuration, however, the 80mm x 50mm dimensions seem to be the stumbling block.
Thanks for the feedback
Does anyone recognize this Fanuc? Dancy Fanuc 14 02-25-2010 12:42 AM
Recognize this profile plcamp Mechanical Calculations/Engineering Design 5 03-19-2009 08:07 AM
SHW UF-2 & ISA 40 anybody recognize? innova General Metal Working Machines 5 04-12-2007 05:13 PM
servos...how to recognize? STUG Servo Motors and Drives 2 02-03-2005 02:26 AM
Can you recognize yourself? ESjaavik CNCzone Club House 4 05-28-2004 10:32 PM
