i'm building a 4x4 router. i purchased 2 acme 48" screws/nuts, but now i like the look of rack and pinion on the y axis. would it work to have the screws on the x axis, rack and pinion on the Y axis, and a screw on the z axis? will they all calibrate themselves in the software? (mach 3, and vcarve pro) |
| Yes Mach3 will let you run different pulses per inch, but it won't calibrate it's self. You need to enter the pulses per inch in Mach3.
__________________ On all equipment there are 2 levers... Lever "A", and Lever F'in "B" |
| The software doesn't normally care what method of gearing you are using. Rack and pinion often requires gearing due to the larger distance per rev when used without reduction. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Alternative to Ball Screw or Rack-n-Pinion | samualt | Linear and Rotary Motion | 38 | 09-28-2011 11:07 AM |
| Rack & Pinion vs Lead Screw | E-Stop | Linear and Rotary Motion | 51 | 08-19-2009 12:53 AM |
| Rack & Pinion Drive | SERVO1 | Mach Plasma / Laser | 3 | 07-25-2007 04:43 PM |
| Ball screw, Timing belt or Rack and pinion | abomination | Linear and Rotary Motion | 10 | 04-30-2007 11:14 PM |
| Rack & Pinion vs Ball screw | jwagner | Linear and Rotary Motion | 1 | 03-25-2006 01:38 PM |
