  #13   Ban this user!
Old 03-16-2010, 06:27 PM
flash319 is on a distinguished road
Got it going last weekend and am very happy. Tuned everything yesterday. Man those servos have a tons of resolution. I had to run my X axis at 250:1 (every step I tell the servo drive it goes 250) steps so that EMC could keep up with counts. The resolution on that motor is 262144 counts per rev (1024 x 256 interpolated) and I am going through a 5:1 reduction. So I end up with just over 5000 steps per turn which is more then enough (about 1600 steps per inch with my 1inch gear). I may try shutting the interpolation off but I thought I would see how it goes incase I want more resolution later.
So now I need some input as to how to make the bed. I see some people use 3/4 MFD. I am thinking about doing that but I am not sure how to frame it in? Should I run a bunch of crossers then set the board on top and counter sink bolt it to the crossers? Any ideas on what worked best for you?
  #14   Ban this user!
Old 07-21-2010, 03:05 PM
Here is my progress so far. Still need to make a table though.
  #15   Ban this user!
Old 07-29-2010, 07:12 AM
rbs rbs is offline
rbs is on a distinguished road
Looking forward to this, just about to start a steel build in similar dimensions.
  #16   Ban this user!
Old 09-01-2010, 11:03 AM
practice cuts.
Build Thread- Building a CNC Router; by someone who can't build a CNC Router Womble DIY-CNC Router Table Machines 2 09-27-2008 07:51 AM
Newbie- Does anyone own a EZ Router Machine? Plasma or Router. sngatlanta Commercial CNC Wood Routers 30 04-11-2008 10:48 AM
Router Using 3/4" MDF (first router build) eguy208 CNC Wood Router Project Log 33 04-11-2008 10:33 AM
Using a router for the 1st time. Need advice of cut speeds, router bits etc. Apples DIY-CNC Router Table Machines 19 09-23-2006 03:33 PM
Surfcam PP for Isel router / Precix router IvanTochev Post Processor Files 2 05-12-2004 12:27 PM
