Old 03-09-2009, 03:33 AM
Rarius is on a distinguished road
Question Sanity check design please...
Can I ask you all to sanity check my design.
Requirements
I want a CNC router to be able to engrave PCBs, cut wood, plastics and aluminium.
History
I spotted a set of part on eBay, including 6 rails 4 spindles and all the linear bearings. I checked against the manufacturers website and found it was almost £200 worth. I got it for £55 posted! RESULT!
X-axis
805mm long 20mm round rails (http://www.worldofcnc.com/products.asp?recnumber=14), 660mm apart, running through 20mm linear bearings (http://www.worldofcnc.com/products.asp?recnumber=16). Driven by a 12mm trapezoidal spindle (http://www.worldofcnc.com/products.asp?recnumber=61). The spindle is stationary and the nut is driven.
To stop racking along this axis, I will add cables such as are used on draghtsmands drawing boards. I am sure this system has been discussed elsewhere on this site.
Y-axis
610mm long 16mm round rails (http://www.worldofcnc.com/products.asp?recnumber=14), 130mm apart, running through 16mm linear bearings (http://www.worldofcnc.com/products.asp?recnumber=16). Driven by a 12mm trapezoidal spindle (http://www.worldofcnc.com/products.asp?recnumber=61). The spindle is stationary and the nut is driven.
Z-axis
455mm long 12mm round rails (http://www.worldofcnc.com/products.asp?recnumber=14), 120mm apart, running through 12mm linear bearings (http://www.worldofcnc.com/products.asp?recnumber=16). Driven by a pair of 12mm trapezoidal spindles (http://www.worldofcnc.com/products.asp?recnumber=61) The spindles are attached to the Z carriage and driven by rotating nuts.
Notes
All motors are Nema23 size.
The router sits in the centre of the Z carriage.
I intend to build it all out of aluminium, but some parts may be made from wood/MDF to start with then replaced with aluminium parts made with the router.
Old 03-09-2009, 10:38 AM
tightredcorset is on a distinguished road
I have seen a lot of designs from home made. The biggest hurdle from any design will be the amount of flex in each axis vs feed speed. As torque is applied the rails must resist flex.
Your design looks sound. The proof of concept will be when you start that first cut. Aluminum will be the hardest. Keep the feed speeds low and I don't see any problems.
Let us know how it turns out.
Lee
Old 03-09-2009, 02:47 PM
dan_the_welder is on a distinguished road
Stiffener
That looks cool. I would suggest a stiffener for the gantry.
Now the lead screw is serving that function. what I mean is when the gantry rails try to flex, they can pivot around the x rail, the only thing stopping this is the y lead screw. Which will be acting on your y lead screw bearings.
If you uses a piece of stock to join the two x carriages then the y rails may still flex, but not as much.
Also since your design is driving only one side of the x axis this stiffness will help keep the other side from binding or lagging.
Not a big deal for PCBs and light stuff but important for aluminum and harder materials.
Have Fun!
Dan
Old 03-09-2009, 03:29 PM
Originally Posted by dan_the_welder View Post
The Y lead screw doesn't move. All three leadscrews are fixed while the nuts rotate and draw themselves along the leadscrews.
I appreciate that I may need to strengthen the gantry. I'll look at doing that.
As I explained in the text, although I am only driving one side of the X-axis, the other side is moved by a cable system similar to that used on a draughtsmans drawing board, so racking shouldn't be a serious problem.
Old 03-09-2009, 04:01 PM
Stiffie
Hi Rarius,
Oh Duh! No end bearings! *Face palm*
So just another plain rod in the missing corner might be all you need, I missed the cable anti racking thing too.
I like rotating nuts, I have never tried it myself and was curious to see that executed.
Dan
Old 03-09-2009, 04:13 PM
Hi Rarius,
Easily done. I'm just thankful to have someone else casting an eye across this design.
Dan
I just finished making the first rotating nut. The original nuts are 24mm long and 26mm diameter. I have turned it down to 20mm and fitted a bearing and 30 tooth pulley onto it. Looks OK.. now I only need to make three more!
Here is an image of the design with the added stiffening on the gantry.
Old 03-09-2009, 04:24 PM
MrRobot is on a distinguished road
Looks good to me.
Old 03-09-2009, 08:06 PM
FandZ's Avatar
FandZ is on a distinguished road
I really like the belt driven nuts. I wanted try that on my build but decided against it for my first build. For a first or even 3rd design i think you did great. That said, I think you need to work on it some more.
I'm not sure if I'm fully grasping your design, but the way I'm seeing it, your spindle will be dropping down from the middle correct? I'm not seeing it upside down? If this is right side up, I'm curious why you have so much room above your z axis?
It looks to me you'll only have a z travel of maybe 2 inches. That would limit your choices of tooling bits a good bit. No pun intended :P
I see you are considering driving the Y axis from one side. Even with a cable support system, you'll be robbing your steppers of power. It can work, but why start with an inferior way of driving it? Steppers are cheap. My suggestion would be to either drive it from the middle (not possible with this current design) or drive it from both sides (the best option for all builds). You could also drive it from the middle useing belts but why waste stepper/servo power...
Lastly, it's a closed box. Which will limit the length of your stock. Consider opening the front and the back.
My last question would be, how do you plan to make this and out of what? I'm not talking about the rails and such but am really asking about the framing and supports. Will you be wielding it together or bolting?
Old 03-09-2009, 08:50 PM
To make explanations easier I have rerendered the design with the bed and I have colour coded various sections of the design.
Frame = Grey
X Carriage (Gantry) = Red
Y Carriage = Yellow
Z Carriage = Blue
Spindle (Router) = Green
You are not seeing it upside down. The image shows the machine from above.
I think I see where the confusion is coming from. What I had drawn was just the main workings of the router. As can be seen from the new image, it will all be mounted 12-18in above the bed. The spindle (green) will be mounted on the bottom plate of the Z axis (blue) and the body extends up through a hole in the center of the Y carriage (yellow). The bit will extend down through the hole in the bottom of the Z carriage.
I have a full 12in of Z travel. As the router is mounted on the bottom plate and moves through the center of the Y carriage, I can move the Z carriage all the way up and down. Of course I don't need this much travel most of the time, so will work much closer to the Y carriage.
Originally I was going to do just that, but after reading this forum for a month or two I rethought the system. From what I read, it seems that two motors on the same axis is just asking for trouble. A missed step on one motor will introduce forced racking.
As far as I have read (both here and elsewhere), the cable system is simple and will transfer power from one end of the gantry to the other with very little loss.
The frame as was drawn will be 400mm above the bed so there is plenty of room to move materials in and out. This can be seen in the new image.
The main frame (grey) is probably going to be welded steel.
The gantry will be 5mm aluminium bolted together
The Y carriage is basically a single peice of 10mm aluminium with bits bolted on.
The Z carriage is a 10mm plat on the bottom and a 5mm on the top.
Old 03-10-2009, 01:45 PM
FandZ's Avatar
I'm on my lunch break so I'll have to keep my post short. I was thinking you'd probably straddle it like you have but I wasn't certain. The length of the Z axis is a little concerning to me. You'll be asking a lof of the round bars to not twist or flex once it is fully extended. Also the forces on your X axes will be great. I don't think, looking forward to you proving me wrong, that you'll be able to mill anything greater than soft woods useing the current setup. I think your Z and possibly your X axis may give you too much sway.
Is there a reason you want so much Z axis travel?
  #11   Ban this user!
Old 03-10-2009, 01:49 PM
FandZ's Avatar
Also, as far as missing steps for 2 motors on a axis, if you are pushing them so hard for them to miss steps, it just means you are pushing them too hard. Any axis can miss steps if you push it beyond it's spindles cutting ability. I'd give it more thought.
  #12   Ban this user!
Old 03-10-2009, 03:46 PM
torleifj is on a distinguished road
Stiffness is king!
My bet is that you'll have a hard time cutting aluminum with a 3mm cutter. And PCB cutting will be a pain because motor/spindle vibrations will kill the cutters. With that type of design, I would doubt that 50mm diameter rails would be stiff enough.
My next PCB mill will weigh 100-150kg for that reason. All ways will be supported.
For alu, I use my 1.2 ton Deckel FP2NC. Even that one can bend - it it is fairly stiff though.
/Torleif.
Check my *cough* logic - H-bridge design. samco General Electronics Discussion 47 04-17-2009 03:56 PM
Chinese laser sanity check SimonArthur Laser Engraving & Cutting Machines 20 12-15-2008 10:11 AM
Newbie sanity check mmm DIY-CNC Router Table Machines 10 11-10-2008 11:34 AM
please check my design. also screw position ? max_imum2000 Mechanical Calculations/Engineering Design 20 06-09-2006 05:57 PM
Sanity check- 6'x10' table Zephrant Machine Problems, Solutions , Wireless DNC, serial port 17 05-13-2003 12:09 PM
