#13
| Nice basic design, however, to go past making it work and using it to work, please shorten Z. Anything besides foam will probably twist it off. Bit chatter alone will kill your cut quality. Why not use track and gears on Y with a drive shaft. Equal torque on all parts when moving on Y. Keep tunint the design, you're ahead of most I've seen. |
#14
| I don't follow. Are you sure you mean the Y axis.. ie the across axis? I can't see why a track would be any better. |
#15
![]() I am not looking to do aerospace engineering quality work. This is my first CNC machine and I expect it to be a learning experience. I'll be satisfied with 0.1mm accuracy. I don't expect to produce something of commercial grade on my first attempt. If you are bending a 1.2 ton mill... I suspect you ought to look into how you are using it.. or sounds like "abusing it". ![]() I have shortened the Z-axis (see below) and doubled up the support. Better? |
#16
| To give you an idea, the Denford weighs something like 250kg, and this was the first one that really did some quality metal work. Still when milling the same jobs on the Deckel, it looks pathetic. Like machining butter. I also have a PCB mill, that is based on a standard X-Y table. The Z axis was mounted on a 60mm steel pole that was standing on a 40mm alu plate. That was flexing so much that it was useless for alu and it was wasting too many PCB routers. I will redesign it with much larger dimensions soon. So my advice to you is to build it as stiff as you can possibly afford. Use huge dimensions for the ways and for the structure. Support the corners. Afterall the raw material is the cheap part of a mill and it will pay off.
Not at all. All mills are bending, some more than others. The stiffer it is, the larger the chips you cut. The Deckel is very stiff for it's size.Good luck with the project. I'm sure that you'll have a lot of fun with it. /Torleif. |
#17
| I couldn't find a price in the UK, but I did find one in the US...the cheapest I could find new was $6000! The cheapest I could find on eBay was still £3000 for a second hand micromill. |
#18
| Oh, beware! There are many types of Denfords. The micromill is a Sherline, it is not stiff at all. You want a Triac with 30 taper spindle. They sell for 1500-2000 GBP in UK. But admitted, they are rarely advertized right now. /Torleif. |
#19
| Secondly, the point of this project is to build it myself. Anyone can go and buy a ready made machine, but building your own is far more challenging. |
#20
And buying a mill won't eliminate the need for building your own. I have many machines and I still build more. When you have the first mill, it becomes the tool that makes it easier to build the next. /Torleif. |
#21
| OK guys... here's the latest incarnation or my design.
| Check my *cough* logic - H-bridge design. | samco | General Electronics Discussion | 47 | 04-17-2009 02:56 PM |
| Chinese laser sanity check | SimonArthur | Laser Engraving & Cutting Machines | 20 | 12-15-2008 09:11 AM |
| Newbie sanity check | mmm | DIY-CNC Router Table Machines | 10 | 11-10-2008 10:34 AM |
| please check my design. also screw position ? | max_imum2000 | Mechanical Calculations/Engineering Design | 20 | 06-09-2006 04:57 PM |
| Sanity check- 6'x10' table | Zephrant | Machine Problems, Solutions , Wireless DNC, serial port | 17 | 05-13-2003 11:09 AM |
