Old 03-04-2009, 08:44 PM
Ranscon is on a distinguished road
How can I increase the feed rate of my machine?
I have a diy (mdf with steel reinforcement) router machine for wood routing. The cutting area is 20" x 40". I'm running Mach 3, with 425 oz/in nema 23 steppers, C-10 bob, 1/2-10 Acme lead screws, and a 24v power supply. My machine runs smoothly at 35 ipm. When I try to increase this in motor tuning the motors "whine" and the gantry stops moving or "slips". There is not a lot of friction in the machine as it moves quite freely when I hook up my 14v cordless drill to the leadscrews. Does anybody have any ideas as to some good starting settings for velocity and accel? I would like to get this to 80-100 ipm. I was told that a Smoothstepper might accomplish this by changing the connection from parallel port to usb. Is this correct? Any other ideas? How do some of these machines with smaller steppers possibly run at 200-300 ipm and more?
Thanks, Jeff
Old 03-04-2009, 08:50 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
Jeff,
What stepper driver are you using?
Need more info.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 03-04-2009, 08:56 PM
ger21's Avatar
This might help.
http://www.cnczone.com/forums/showth...639#post256639
Old 03-04-2009, 09:07 PM
Eurisko is on a distinguished road
Hi Jeff,
You didn't mention what stepper driver you're using. If the driver can handle more voltage, go for it. More voltage = more power to the stepper.
You can also replace the 1/2-10 acme rod with a 1/2-10 2 start acme rod. This will give you twice the linear speed at the same rpm.
Old 03-04-2009, 10:07 PM
My drivers are Keling 4030's. How do the 2 start acme screws change the speed at the same rpm? Will they also increase the load on the motors? I've seen them but don't understand them.
Thanks, Jeff
Old 03-04-2009, 10:25 PM
jalessi's Avatar
Dampers will help a lot if this is what you are experiencing.
After adding dampers you might consider raising the power supply voltage to 36-40 volts, that will increase rpm about 30 percent.
Changing the screws to 2 start would double your feed rates.
Jeff...
Old 03-04-2009, 10:35 PM
jalessi's Avatar
Post Screw Start Diagram
Screw Start Diagram:
Name:	Screw Starts.JPG‎
Old 03-04-2009, 10:36 PM
jalessi's Avatar
Post
The number of starts on most threads is one (single start). However, a number of thread series including Roton's Hi - lead(r), Torqspline(r) Lead Screw, and Ball Screw series screw threads may have from 2 to 20 starts or more. Multiple starts are used to increase the lead (linear advancement per revolution). In most cases, increasing the number of starts is preferable to increasing the pitch because larger pitches reduce the minor diameter. A small minor diameter decreases the screw stiffness and makes it more difficult to tap nuts because of the likelihood of the tap breaking during tapping. Also, for the same lead, increasing the number of starts actually increases the thread contact area when compared to a thread with the same lead but using fewer starts and a coarser pitch. Close examination of the thread will reveal the number of starts (Figure 49). Simply place a pencil or marker pen in the thread groove and rotate the thread one revolution. If the end of the pencil mark is in the adjacent thread groove, the screw has a single start. If there is one thread between the beginning and the end of the mark, it is a two start thread, two grooves, a three start thread and so on. Another way to discover the thread starts is to examine a transverse section of the screw. As illustrated in Figure 49, if the end view is an offset circle, the screw is single start. A two start thread will have roughly a football shape, a three start thread will have a tri-oval shape and a four start thread will be noticeably four cornered. Usually, five starts and up can simply be counted in the transverse section.
Old 03-05-2009, 12:16 AM
Thanks Jalesi,
That is an excellent description of the screws. So with 2 starts, will the same nuts work? They will just move across twice the distance per revolution, correct?
Thanks, Jeff
About the dampener, That video could be from my machine, That's exactly what it does. What can I use as a dampener and how do I determine the weight? The one in the vid looks a bit dangerous to me. I think I prefer the disk type.
Thanks again, Jeff
Old 03-05-2009, 12:34 AM
FandZ's Avatar
FandZ is on a distinguished road
Woa, I've seen the word Dampers thrown around before but it is the first time I've seen one in action. It looks like something I would be interested in putting on my machine once it is done.
Is the point of them to help the steppers to not loose steps by giving it a little torque support? If you have any additional infor and their prs and cons I'd really like to read about them.
YouTube - 65 ipm
Jeff...
  #11   Ban this user!
Old 03-05-2009, 01:57 AM
jalessi's Avatar
Post
FandZ,
The damper helps to suppress resonance, see the attached documents for more info.
http://www.ferrotec.com/products/fer...nertiaDampers/
Jeff...
  #12   Ban this user!
Old 03-05-2009, 09:01 AM
FandZ's Avatar
FandZ,
Jeff...
Thanks for the link. I guess I'll see how my machine does once it is up and running. I'm just glad I'll be ready for the problem if it pops up.
Problem- c axis feed rate on a turn /mill machine bike G-Code Programing 5 09-29-2008 07:57 PM
Need Help!- Feed rate for 5/8-18 tap Eagle View General Metalwork Discussion 2 09-24-2008 10:25 AM
Need Help!- Feed rate Ovverride also Increases rapid rate. Korellibopper Machines running Mach Software 1 01-30-2008 06:37 PM
Feed Rate and Spindle Rate for this cut? DroopyPawn General Metalwork Discussion 20 11-22-2007 12:12 AM
How can I up my feed rate ? ynneb DIY-CNC Router Table Machines 7 07-12-2004 10:40 PM
