#13
| Unfortunately, you need a multi-start nut (with the same number of starts and pitch as your screw) if you switch to a multi-start screw -- you cannot use the original nut. It will not physically fit. That being said, I highly recommend multi-start screws. My machine went from ~110 IPM to 300 when I went from single start ACME to 5 start ACME. There are two big advantage of multi-start screws for stepper applications. 1 is the increased linear speed at the same RPM, as stepper motors produce more torque at lower RPMS. 2 is the increased efficiency of higher lead screws. This is just an inherent reduction in frictional losses due to the higher contact angle of the threads. Hope that helps, Ahren www.cncrouterparts.com |
| Problem- c axis feed rate on a turn /mill machine | bike | G-Code Programing | 5 | 09-29-2008 06:57 PM |
| Need Help!- Feed rate for 5/8-18 tap | Eagle View | General Metalwork Discussion | 2 | 09-24-2008 09:25 AM |
| Need Help!- Feed rate Ovverride also Increases rapid rate. | Korellibopper | Machines running Mach Software | 1 | 01-30-2008 05:37 PM |
| Feed Rate and Spindle Rate for this cut? | DroopyPawn | General Metalwork Discussion | 20 | 11-21-2007 11:12 PM |
| How can I up my feed rate ? | ynneb | DIY-CNC Router Table Machines | 7 | 07-12-2004 09:40 PM |
