Old 03-03-2009, 10:31 PM
ttjarrett's Avatar
ttjarrett is on a distinguished road
Power Supply Wattage
Hi All,
I am currently in the process of my first build (First CNC - MDF Build) and am reassessing my controler/power supply options. I have purchased a HobbyCNC package and intended to build my own power supply, but I am now considering a Gecko G540 unit and purchasing a power supply.
The power supplies I am looking at come in a range of wattage variations, and I don't know which would be appropriate for the G540 with 4 nema #23 size steppers with around a 205oz rating.
Could a wiser mind than my own please explain to me watts and how they relate to CNC controlers and stepper motors? How many watts does a stepper motor need? Do more watts equate to faster stepper motor speeds? Does none of this matter? I'm stumped!
Toby
If it can't be fixed with a hammer, you've got an electrical problem...
Old 03-03-2009, 11:46 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi Toby! If those motors are Homecnc 23-205-ds8s then you will need a 48 - 50V PSU that outputs at least 10 Amps. The $129 Keling KL-5010 would be just right. http://kelinginc.net/
One note about these motors. They are 205 oz in Unipolar. But with a G540 you will want to wire them in Bipolar Parallel. In THIS configuration they are 4.2A 285 oz motors. The G540 can only accept 3.5A max, so the actual rated torque will be about 240 oz.
The motors you have are not the most efficient choice. Although, if you are running with 2 motors slaved to the X axis, They might work well there. It is customary to use a slightly more powerful motor on the Z axis because it has to lift weight against gravity.
If I were advising you from scratch, I would recommend this:
$299 G540 http://geckodrive.com/product.aspx?c=3&i=14469
$117 Three $39 KL23H276-28-4B 270 oz motors for X & Y
$049 One KL23H284-35-4B 387 oz motor for Z
$129 One KL-5010 power supply.
$010 Estop switch
$604 Total electronics cost.
$149 Mach3 ($25 discount) cost with above purchase.
Keling has all of this, and ships at warp speed. http://kelinginc.net/
CR.
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 06:13 AM
Recommended Wattage for 201 Current Set Resistor? cmnewcomer Gecko Drives 2 04-27-2008 07:42 PM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 08:03 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 03:56 PM
Soldering iron wattage rocks101 General Electronics Discussion 4 02-06-2005 01:52 PM
