Old 03-03-2009, 09:44 PM
eloid is on a distinguished road
servo motor specs
seen a servo motor that has Torque,continuous Lb-in 10.84 dont remember the converstion... is this motor any good for a cnc ie a z axis
Old 03-04-2009, 01:34 AM
H.O H.O is offline
H.O is on a distinguished road
Hi eloid,
10.84Lb-In = 173Oz-In = 1.2Nm, roughly.
Can't say if it's usable for you though since one "CNC" is not the same as another "CNC". For a small router, probably overkill, on the X- and Y axis of a small mill probably with the correct gearing, on the knee....perhaps but depends how heavy the knee is and how much you can gear it....on a large machining center - forget it. You get the idea.
The large servo-motors from HomeshopCNC are 170oz-in continous and are being used on knee mills with good results I believe.
SWI Prototrak Servo Motor Specs? Bruce Griffing General Electronics Discussion 1 02-27-2009 09:26 AM
SWI Prototrak Servo Motor Specs? Bruce Griffing Servo Motors and Drives 0 02-19-2009 01:03 PM
SM-1 Servo motor specs tjs88yj HURCO 6 03-26-2008 11:06 AM
Boss 8 Servo Motor Specs? TurboStew Bridgeport and Hardinge Mills 0 10-20-2006 12:46 PM
servo motor specs and help cowanrg Servo Motors and Drives 3 06-11-2005 07:11 PM
