Old 03-03-2009, 02:07 PM
Mark Phillips is on a distinguished road
Hello, New to the forum
Hello all, I'm new to the forum. I'm a sign maker and an artist and looking to try to build my own CNC router. I have wanted one for years and always thought they were financially out of reach. Glad you DIY people are around. I guess my first question would be if I bought one of Joe's 4x4 hybrid kits how much would I need for the motors and other things such as software and all the extras to make it work.
For my sign business I have special software for using my plotter but doubt it will drive the router (no 3D and Mac based). I may be able to upgrade that software but since it's for the sign industry they'd want an arm and a leg for it.
So what should I expect to be in for money-wise (ballpark highs and lows) and what's the best way to get started? Is anyone selling a complete kit or are there so many custom considerations that it's all in what I plan to use it for? I've been reading the forum posts but getting a little confused on what I need.
I'll be cutting HD Urethane foam, redwood, some aluminum, acrylic, PVC, and other basic sign and art materials. I'd like to be able to carve/rout 3D with some detail and control for my signs. I figure the 4x4 will accomodate most signs I'd make and I can always upgrade after I get the basics down. I figure building these things are addictive and I'll want to go bigger and with more bells and whistles with the second one.
So where to start?
Old 03-03-2009, 03:21 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi Mark. Welcome to the Zone!
You haven't said anything about how you are going to drive the axes so this could change but generally you can probably use a G540 controller, 270 oz N23 motors for X and Y, a 387 oz motor for Z and a 48V 7.3A power supply.
$299 G540 http://geckodrive.com/product.aspx?c=3&i=14469
$078 Two $39 KL23H276-28-4B 270 oz motors for X & Y
$049 One KL23H284-35-4B 387 oz motor for Z
$060 One KL-350-48 48V/7.3A power supply.
$010 Estop switch
$496 Total electronics cost.
$149 Mach3 cost with above purchase.
$645 To spend at Keling. http://kelinginc.net/
This most likely will be the best electronics for your 4 x 4 router.
Start by reading this:
http://cnczone.com/forums/showthread...709#post572709
CR.
Old 03-04-2009, 05:50 PM
abomb55076's Avatar
abomb55076 is on a distinguished road
Welcome! Sounds like your going to building the same type of machine I built. I build one mostly for the fun of it but instead lead to carving signs and artwork. As for software, most people go for mach 3 because its easy to work with and not too bad for price. I like it alot. The price can vary greatly and depends on the materials you use to build the machine. In my case, I had no money to build the machine, but in the end ended up with a pretty solid machine. I just looked around for used parts, and materials and actually ended up using an old military bullet inspecting machine for the majority of my parts including both my y and z axis, and the table top. Take a look at www.homegrowncnc.com, theres alot of information pertaining directly to diy cnc machines. Good luck
Check out www.Homegrowncnc.com for free CNC machining info for the average joe!
Old 03-04-2009, 06:48 PM
ger21's Avatar
The best bang for the buck for sign software would be from Vectric. Check out V-Carve Pro and Aspire, if your budget allows.
www.vectric.com
Old 03-05-2009, 10:29 AM
Thanks guys Good info
Now that I have a basic budget set out I can get things together to get started. No Mac systems out there eh? I can pick up a used PC pretty cheap I guess. The software link seems pretty reasonable in price. I know I spent over 3K for my original sign making software 15 years ago so this seems like it's more in reach.
Thanks for all the replies.
Old 03-05-2009, 03:36 PM
These are pretty cheap and come with 1 year warranty. Make sure it has a Parallel port and XP--NOT Vista.
http://www.tigerdirect.com/applicati...+lease+desktop
CR.
Welcome to new forum cadcam UG NX 14 11-04-2011 04:28 PM
New To this forum katiebo General Metal Working Machines 1 03-02-2008 11:47 PM
where is the EDM forum CNC_BOB General Metalwork Discussion 1 09-20-2007 11:01 PM
New Forum Look Rekd CNCzone Club House 32 07-20-2004 12:00 PM
